I have a few Tri-Z and other shocks I need rebuilt. I do not mind doing it myself, but I have never done it before. The local shops want $130 and up a piece to do it. Why are they so expensive and is there a cheaper alternative?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
83 YTM 200L For sale,
82 Tri-Zinger 60 For sale,
8? YTZ 80 Conversion,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
just get the fork seals and ATF/fork oil and dive in. Its really not that hard. Just make sure you pay attention to how everything comes out.
I put a bushing in my 350x bottom tube before the slider, and lets just say that bushing was trashed by the time i pryed it out with a cats claw and a blowtorch.
If your seals arent weeping/leaking, just wash everything out with kerosene.
You will need a fork seal driver, i made one out of a piece of metal pipe.
Just go for it...my honda dealership wanted 120 for my 200s forks to have new seals and that didnt even include the fork oil. I did it myself for 50 bucks, for the seals and the fork oil.
Hop this helps,
Mike
Are you talking about the front forks? Thoase I can rebiuld. I have done quite a few. I was refering the the rear coil over shock.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Good used shocks are cheaper than rebuilds, and rebuilding requires specialized equipment, including the ability to deliver pure Nitrogen at 300psi. $130 is a bargain to get one rebuilt. A good used Warrior shock sells for $95-$140.
Only problem with rebuilt shocks is you never know what you got untill its installed on the trike. $130.00 is a good deal, the cheapest I found around here was $180.00
86Honda250R
85Honda250R Sold
82Honda250R
Tiger 200 198? Sold
Tiger 250 198?
Tiger 80 (need engine) Sold
85 Tri-Z
86 Tecate
Perfection consists not in doing extraordinary things, but in doing ordinary things extraordinarily well.
Wow. I had no idea. Is this something I can do my self with out special equipment, then have it filled?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
You're not going to be able to do it. To much high pressure stuff involved. I'm checking locally to get my x recharged, I polished it to a mirror finish and its flat. If I find someone locally to do it, it might be worth your're while to mail it this way. I have a good friend that knows alot of people in the business.
'02 ranxher 4x4 '83 big red '84 110, '86trx70 project, '85 bigred project
Are you just wanting new oil and recharge? Or internal work? I never changed mine in the 85 tri-z. blew it out at a mx race in 85. had to buy a Ohin. I had changed the fluid in a 250r shock and then had them recharge it. Best bite bullet and let the dealer fix it. That is what I've done last few years.
Oh forgot to mention the bleeder valve on the reseroir. it is like a tire valve
my buddy had his yz250 rear shock rebuilt with new oil and seals and charged for $60. thats a deal he couldn't pass up. but i didn't think they were much more than that. i had my quadzilla shock rebuilt and revalved and all the parts done for $200 shipped back to me. derise racing did it.
and it is possible to do it yourself. i've done them. you just have to know how much oil to put in and clean all the oil out of them. for the nitrogen i used to work at a welding shop and i got a regulator that goes up to 400 psi with a tank of nitrogen.
and some of the old motorcross manuals tell you how to rebuild shocks.
Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
My Feedback
http://www.3wheelerworld.com/showthr...k-for-sblt500r
If you have some machanical skill, & take your time you can re-build the inerts, usually the seal head seals go bad (seals the shaft & seals the inner shock cylinder). Make sure the shaft isn't pitted, and the inner bore isn't worn or pitted. The hardest part is bleeding out the air when you fill it with oil. Just don't mix up the shim stacks when you take the seal head off the shaft. Then you have to find someone to charge it. That might be the hardest part finding someone to trust your work. I also have a nitrogen tank & adaptor at work, we use it to charge steering cylinders on big loaders.
My Tri-Z shocks does not have a vlave stem style valve. But the eboch shock does. I am geeting the impression there is no way to avoid the big money. i have looked up the break downs and they looks imple enough for me to do, but I am worried about getting them filled. I am wondering if I can get them filled after the fact. I was told it would only cost me $15. Everything around here cost triple than other ereas because there are not many shops that do this sort of thing. If I was to send it off, who would be a good choice?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
you need a innert ingredient any way ,,, how about those paint ballin people.
maybe check them out as to what they are re-filling their canisters with.
most up my way use a scuba tank but i have heard tell of nitrogen being used.
john
paint ballers use carbon dioxide. shocks get fillled with nitrogen. nitrogen is also good for filling tires. it doesn't change pressure with temperature. if you go to a welding supply store they should be able to fill it for ya. or sell you the items needed to do it.
get a atv magazine like dirt wheels. they have alot of businesses that do shocks. call around and you will probably find a better price.
that triz shock might be a sealed shock. which means its a throw away. but i wouldn't think so on a rear shock for a triz. almost every rear shock on a 3 or 4 wheeler is rebuildable.
My Feedback
I will do that. I was hoping some one here might save me some time and recomend a place. oh well, it gives me an excuse to dig through my magazines. The price I was quoted is for a Tri-Z shock. They are rebiuldable.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
