TRI-Z
Well thanks to Olds86 I have a rear shock(thanks very much)
But.... I got it recharged got it home and the recharge was gone, the worst part was I didnt know after I installed it so I was driving around like a bobble, up and down-so springy lol
so I need seals. Where can I buy seals, if I need them?
I still have my stock 86 shock I broke at the base with perfect seals, can I switch seals and put them in Olds86 shock he sent me? I know this idea I am about to say is a Hick Fix, can I weld my base to silver shaft? or will that not work?
heres a pic of a different shock(see below), but I show whats wrong with mine- can I use the base off OS86 shock and put it on mine?
ATC200-
My shifter is loose, the bolt that tightens it to the shifter shaft is stripped. I tried really reeming on her to get it tight, tight as it can go and it wont bite and stay on a spline. So do I use locktight?
thanks for the help guys![]()
and.... I painted my pipe with high temp BBQ paint. Would to many coats make it flake off? its starting to rust now![]()
not running yet. but won't be long.
