Page 2 of 2 FirstFirst 1 2
Results 16 to 18 of 18
Thread: Wrong pulse generator?
    Jul 2004
    Mud hill. close to water !
    3,658
    Ok. the pictures did not have that portion of the case.. sorry.
    However. since you're in there.. the ES and the SX tend to suffer from a problem with the shift pins.. check this thread out ...
    http://www.3wheelerworldforums.com/s...ight=shift+arm
    Currently :
    May 2005
    brooks, Maine
    13
    Found the problem. Pulse Gernerator was fine. The second wire, the "missing" wire is connected to the back of the stator. It had come loose. I took the stator off to check the connections on it and found that ground for the stator and PG are connected to the stator with a screw. The ground to the PG is made by mounting it to the cover which the stator is mounted to also. Everything looks original. That is, it doesn't look like a jerry rigged connection. Either it came like that from Honda or the stator and PG are after market and designed differently. If anyone knows any more info about this setup, I'd like to here what you know.
    Thanks for the help bigrehead!
    Jul 2004
    3,658
    Ha.. son of a gun !
    That's cool !
    I guess electrical diagrams are made with a standard sybol for connection.. the pictures in the clymer ( black and white.. ugh ) SUCK !.
    How she run now ?
    Currently :
