Results 1 to 8 of 8
Thread: 350x chain breaking
    toyvette81 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    durham
    284
    350x chain breaking
    yesterday i put on a 14 tooth front sprocket to replace the stock 13, my low end was good enough.... the only thing i regret about it is that i cannot use my case-saver this makes me a little uneasy... what is the likeleyhood of my chain breaking?, i imagine there pretty slim if i keep it adjusted correctly... right? or has any1 had their chain break with out a casesaver? i may just change the rear sprocket to a 7% difference and use my casesaver, that would make me feel better.
    Phoenix, AZ.
    6,719
    Doesn't anyone make an aftermarket case saver that would fit over a 14 tooth?
    Opelousas, Louisiana
    1,337
    i think you can notch or modify it and make it work.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    durham
    284
    the thing is so thin already i didint think there was an aftermarket 1 to fit in there it would have to be paper thin b/c this 1 is only about a 1/4 inch thick
    May 2002
    Southeastern Wisconsin
    3,658
    You could put the 13t back on and your case saver then add 3 teeth to the rear.
    r00sty's Avatar
    r00sty is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2002
    Hemlock 14466
    415
    Mine fit with the 14 tooth......
    Old enough to know better, but still young enough to not care!!!
    Reality is for people who can't handle drugs!!!
    86 XR250RX Custom but all Honda...
    92 Yamaha Vmax
    81 Yamaha XS1100
    04 Polaris 700 Twin EFI
    86 TRX 250r
    Nov 2001
    B.C.
    933
    I have a 14 on my 350x witha "stock" Honda chain guide still in place. All you have to do is Use a die grinder or Dremel with a burr tip and take 1/3 to 1/2 of the material off of the inside of the curve until it all goes together with out rubbing. Takes no time at all.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    durham
    284
    ok thats good to know
