I dont think its too difficult in there at all, as along as I have atleast pictures (like the ones that can be found on bikebandit) it should be fairly easy going back together. One of the gears in the tranny was rubbing the case abit, because there was a thrust washer missing.
The kicker gears slipped when the engine was cold... what should I look for, the spring?
also now is probably the time to put a xr tranny in there.... would that work with a stroker?
I need some parts too
crank (on mine the threads are stripped on the right side.
also need a good left inner case, mines cracked, and it seems as if where the crank bearing goes into the case is stretched abit.
anyone have any pointers (to do's/not to's ?? )
Thanks for any help.
or anything.....maybe tap it with a rubber mallet.
