Is there a way I can put a Tach on my 200es? I was going to pu ta speedo on it but would be cool to see my revs too.
1984 Honda 200es Big Red
Bored out
Aftermarket Exhaust
K&N Air Filter
Unfortunetally Blew the engine and got in a bad accident![]()
1984 Honda 200e/200es pieced together (parts machine)
1984 Honda TRX200 Works, but also needs work
Yes,you can buy a cheap one from Dennis Kirk.You just attach the green wire to the the coil wire that goes to the spark plug.I think...![]()
My old 1985 250R http://www.flickr.com/photos/24898661@N07/show/
Feedback http://www.3wheelerworldforums.com/s...feed+back+edog
Currently trikeless
i had considered one of those fancy ones those kart racers use with b&s's and shifter motors
-1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
-1986 kx80- S O L D
Nope don't connect the green to the coil your blow the tacho...... the coil wire is the Black/Yellow!!!!!!! green wire is used for power to the tacho....
yep... what he said!Originally Posted by petesatc
Hondaline Hartman <---- <shakes head at edog>
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
Sorry, the Yamaha one i have is that way.
Currently trikeless
