Results 1 to 11 of 11
Thread: Hey Guys. How About Some Help With Tires!
    Feb 2005
    Canada
    663
    Exclamation Hey Guys. How About Some Help With Tires!
    Hey i just need some help. I have a TriMoto 175 ported polished and all that junk but i am running 22-11-8 tires on it. I ride all hard pack and grass and am inteseted in putting a set of 18's on it. I know it will probably look stupid but im interested more in proformance then anything else but am willing to sacrafice a little top speed cause shes fast enough anyways. Any help or suggestions would be great. Thanks.
    nimda78's Avatar
    nimda78 is offline At The Back Of The Pack Arm chair racerFirst time rider
    coeburn va
    177
    id go for it, lower center of gravity, more torque.. post some pics if you do it.
    -1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
    -1986 kx80- S O L D
    Rittman, Ohio
    6,276
    I think youre going to find that when you put some low profile tires on there, that you will suddenly discover the practical purpose of a taller bouncy flexible sidewall tire on an unsuspended trike. Your tires are your rear suspension. Keep that in mind when choosing them.
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    DITTO what Tim Sr. said for sure. 20 plus inch diameter high sidewall tires are a good thing on a hard tail trike. Trust me, I got 2 of them. Anything else will beat your kidneys to a pulp.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    Feb 2005
    Oregon
    772
    If you can handle the ride go for it, I put 20" 6 plys on the T-3 and my god it slides good, you can see a video of it on the dune trike thread and thats on asphault and I really dont have to get off the seat to get it to slide although im runnin quite a bit more power than you. If you ride in grass it would defiantly be fun should handle like a new machine.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Feb 2005
    Canada
    663
    thanks guys anymore suggestions. But i think im gonna go for it and mount some 18's
    Houston,Texas
    1,044
    I think some 18'' Titan Turf Tamers are what you need. They slide and hook up good. They look cool also.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Central CA
    459
    Turf tamers have too much traction, go for Duros or Hoosiers !!! If there is a mini-sprint car track nearby, You can get them (slightly worn) for free !
    86 250R
    86 250R
    86 250R
    85 250R
    82 250R
    86 350X
    81 185X
    85 250SX
    87 200X
    Sitting on my can can, doing the pan-o-ram..
    Feb 2005
    Canada
    663
    ya theres not one of them around here but theres a few junk yards and stuff around here i can check. Here in canada Turf tamers are about 85 bucks a piece to order so i think im gonna go with them. According to most of the people on this board there a great tire. I havent heard to much bad feedback about them.
    Rittman, Ohio
    6,276
    Grass is what Turf Tamers were made for as the name implies. They also make a good track tire which is where I use them. As a trail, mud or woods tire, they are a joke, especially as an 18". For the uses you mentioned, they will work fine other than beating you half to death on your unsuspended trike on anything other than a smooth surface. They are made to be run very hard, at about 6 or 7 psi.
    Feb 2005
    Canada
    663
    So how hard would it be on the axel of a hardtail trike with a set 18'2s on it??
