Results 1 to 15 of 21
Thread: Choosing a pipe for the ATC-500R project
    Mar 2004
    North Central Ohio!!
    2,712
    The 500 needs a better pipe. The beat up old stocker just isn't going to work. So here's the choices available still for the 85 500.
    I can get a Pro-Circuit pipe (which appears to be chrome or nickel plated)
    or a DG National pipe (Think this is what Billy has on his 500)
    or an FMF "Gnarly" pipe (which is also chrome or nickel plated)
    So, those are what I have to pick from. Can anyone tell me the power ranges these pipes are designed to operate best at? I'm looking for good smooth power, nothing that will hit hard.
    Jun 2004
    potsdam ny
    1,227
    just call up each company..they will help you out...
    Aug 2004
    Ab Canada
    4,368
    The pro-circut if its the platinum is a midrange-top end pipe that hits hard
    1985 Tri-Z-
    May 2005
    Southern NH
    1,489
    FTZ pipe, looks sick on Mike Hollands, readers rigs page 19
    "I have but one lamp by which my feet are guided, and that is the lamp of experience." -Patrick Henry
    NEW ENGLAND ATC owners please join!:http://www.3wheelerworld.com/group.php?groupid=27
    Mar 2004
    Eastvale, CA
    629
    I think Kasey had one custom made for his 500R by CT Racing. I'd contact them or ESR and see what they can do for you before I went with one made exclusivley for a 250.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Mar 2004
    2,712
    My bike is a CR500 converted. It takes a standard 500 pipe.
    Mar 2004
    Eastvale, CA
    629
    Your right, it is, I remember reading that somewhere a while back. I guess CRS is setting in.
    got sand?
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    Yeah, I've got the DG on mine. I've also got an FMF that I tried out before I went to haspin and didn't like it. Took ALL the hit out of the power. No topend at all, and a little bit more lowend. Complete opposite of what I need for my application but it migth work perfect for you Derrick. If your interested in mine, PM me. I had to cut a short portion of the end of it off where it was swedged for the silencer to go in because at the time I was considering on trying to use it in conjunction with another type of silencer to get it quieted down but I never got to it. Its got a little bit of surface rust but not bad.
    Also from what I understand, the Pro circuit is more of a topend-ish pipe. I've been wanting to try one out, might be better then my DG.
    Jun 2004
    AZ
    43
    cr500 pipe
    There is a company called Power Pros thats builds a lot of the pipes for the above mentioned names not sure of a number but ill see what i can do to find it.
    Jun 2004
    AZ
    43
    here is the information for power pros well at least the web addy
    www.thepowerpros.com
    Mar 2004
    2,712
    Kind of interesting that an aftermarket pipe would kill the power, huh? That maybe right up my alley, though. I really want smooth power delivery for the type of riding I will be doing. Thanks for the tip!
    Houston,Texas
    1,044
    Quote Originally Posted by Derrick Adams
    Well, not really kill the power, but they move the power to a different RPM range. Some pipes are made for low-end, and some high end.
    "I am going out of this world.....the same way I came in...screaming and covered in blood."
    Anaheim
    1,270
    fmf is the lowest in low, MTS, is right about the pro-circut, it hits alittle higher and ALOT HARDER, like pullin a good 3/4 sand drag wheelie out the whole hard, the fmf sorta brings out the torque monster more (but how the hell you do that! its already a beast!), the fmf tho does drop off right after mid rpms, if you go smaller carb jetted up, and a weighted flywheel O BOY it will be a tree climber/woods rider, if you go pro-circut and bigger carb/ porting and you will have a OUTSTANDING screamer on top end
    adam
    86 ATC 500R the duner..
    85 ATC 500R...the not quite finished faster duner
    1985 ATC 250R Bone stock!!
    1985 ATC250R mx/duner
    1986 TRX370R MX/Duner
    94 Banshee 400PV Cheetah 105RWHP
    Fresno Ca
    2,695
    I gota fmf gold series for sale. From what i hear its a hard hitting topend pipe.
    Live Oak, FL
    15,069
    the Gold series I have is most definetly not a topend pipe...
