Results 1 to 8 of 8
Thread: 200x axles and rear shocks
    Nov 2004
    OH.
    2,487
    I'm having no luck finding a rear axle and shock for my 83 200x project.
    My question is will other makes of Honda ATC or ATV axles & rear shocks fit a stock 200x swinger.
    I've tried my local machine shops to see about straightening it. They say no or want too much to do it. Plus the threads on one side are shot.
    I've seen a bunch of axles on Ebay from 250r, 110, 125m, and 185s. All for reasonable buy it now prices but I don't want them if they don't work.
    Also, the rear shocks for 200x's look different depending on the year. Are they all the same but some with the little bracket on the bottom?
    Any help would be great. Trying now to get this done by the Labor day weekend Rumble on the Ridge.
    Jan 2005
    Great Bend
    704
    the 82 250R axle will fit the swing arm
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Nov 2004
    OH.
    2,487
    Are you positive? I"m not doubting you but there is one on Ebay right now that I will buy if it will.
    Old 179's Avatar
    Old 179 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Southwest Indiana
    300
    I do know for fact a 82 250r Dura blue axle fits 83 200x. You would think the stock axle would too. Can not help on shock!
    Nov 2004
    OH.
    2,487
    Will I need the R 's sprocket too or can I use the 200x sprocket? Or maybe change the whole hub with the sprocket?
    Jan 2005
    Great Bend
    704
    sorry for not claifying but yea you do need to use the 82R rear sprocket for the swap to work
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    Nov 2004
    OH.
    2,487
    thanks for
    the info
    Old 179's Avatar
    Southwest Indiana
    300
    hey atc wrench, i don't recall the changing of the back sprocket. enlighten me! My buddy bought mine back in 84 and never said anything about it!
