will a 85 200x headlight guard bolt onto a 86 350x tripple tree?
1985 atc 110 for sale
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
uni clamp on air filter
350x front end
or maybe an 83 84 r headlight guard fit on? im just looking at my options i dont wnat to the 350x headlight on my 200x(they area about 100 bucks for a nice one) so i want any year 200x or the early r headlight.
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
The air cooler R has the HL guard allready built in! So you'de have to switch everything including the headlight.
Now a 200x guard.... I know it will bolt up fine on the triples, but it might look silly or might not even clear the HL plastic. The 350x and 200x headlights are quite different!
There is a dude that sells wierd looking chrome 350x guards on eBay, $60 BIN
Here is a pic from my archives of a 200x with guard.
Oh... also here is a pic of the 350x guard I'm talking about mounted on the machine.
Last edited by Maine_Triker; 07-30-2005 at 10:19 AM. Reason: attached wrong pic..............
'85 350X-The Flagship
Speedo, Chrome HL Guard, Rubber Steps
DG Chrome Power, 6-Pack Rack, White Bros Skidplate, 400ex Carb
'85 250ES Big Red-Working in Style
Many Hondaline & Aftermarket Add-ons
'84 250R-Old School Racer Project
Too many Accessories to List
'82 200E Big Red-The Tractor
Rubber Steps, Tripmeter
'85 250SX-Rider
Various Accessories
'13 CBR250R & '05 CBR600F4i-Road Toys
Yoshi Slip-Ons & Fender Eliminators
If you have 350X triples on your machine, a 200X headlight guard I'm about 99% sure will mount onto the triples.. Well... If it's a Hondaline HL Guard and mounts to the top and bottom cross bars of the tripple and not the fork mounting bolts like some aftermarket ones. HOWEVER, I am not sure how you would mount a 200X headlight, because it uses those little bolt on things under the top triple and the posts that go into the lower triple right??? (350X has the rubber quick disconects around the forks for the HL mount) A 350X will NOT have these places. Now, a 83-84R triples/forks have the same diameter as a 350X.... wonder if you used a set of 83/84R triples if you could mount the 83/84R headlights and slap the 350X forks into the triples??? If you have a 83/84 Headlight, it does have a sorta built in guard, but then you can get a "Lens Protector" guard from Hondaline... they came in chrome, and either black or red... It's basically a wire grid that goes in front of your headlight glass.
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
If it's the kind that bolts on to the fork mounting bolts it will work as well, that's what's on the SX w/200x front end (350x guard that bolts onto the fork mounting bolts)
Those Lens protectors are cool. They also made an aftermarket one, one which I have sitting on my shelf.
Here is the Hondaline one:
'85 250SX-Rider
Various Accessories
the 350x looks like it has the holes so you can mount up the 200x headlight if im not mistakin. it has the 2 holes on the bottom tripple. what i want to do is mount a 200x headling on my 200x but i have the 350x front end. so will a 200x headlight and guard work on the 350x tripples is what im asking. it looks as it will.
new carb
old trike
1985 200x
12.1 piston
oil cooler kit
white bors cam
super trapp exhaust
350x front end
Dude... then just do it and stop asking us! I don't have a 200X headlight ... well I should say I don't have a 200X mounting brack to test it out. If you have a bracket then try it! If it works... let us all know.Originally Posted by vartiak15
I have both machines and the guard I have which is red and I don't really like,fits on both of themAlthough it isn't mounted on either of them
and I don't know which one it is for but I did get it with my 350x.
1985 Ytm 225 dr (Black and gold)
1984 Kxt 250 A1 Tecate
1981 KLT200a1
1983 Yt 175
1985 Atc 350x
1983 Klt 200 C
1985Ytz250 Tri z
In my mind it's not a question of the guards fitting... my question is if the 350X triples have the places on them for the 200X headlight mounting bracket.Originally Posted by atckowalski
Bruce
look at 86 200x headlight or 250r. Like what 350x'inNy said. You have to use the headlight with the little rubber quick disconnect thingys. Now With that being said the 86 200x headlight grill will fit the 350x.
www.3wheeler.org
* * * Nothing scares me more than someone who knows, with certainty, what is best for me * * *
Today I noticed that my 350x (which I bought had extra front forks)may not have the right front trees and shocks on it, so I have to change my reply to, I am not sure if they are the same. Thanks![]()
1981 KLT200a1
1983 Yt 175
1985 Atc 350x
1983 Klt 200 C
1985Ytz250 Tri z
