Thread: Help Me Pleeeease!!!
    Feb 2005
    Canada
    663
    Hey whats up. I have a Yamaha Tri-Moto 175 ported polished and all that crap but when i put it into first it starts to roll very quickly without even touching the throttle. even when its ideling slowly and i pop it into first gear i get a pretty big jolt out of it. It also seems to be running really hot even when it is just ideling but maby thats just because its air cooled. There also seems to be a pretty loud piston rattle but the top end was just done. Would it be a fiel/air mixture problem or throttle adjustment or what. iv tried almost everything i think. Any help would be great
    Apr 2002
    s.w. michigan
    6,498
    auto clutch
    the one way bearing is shot. they very well might call it something different in a yamaha but it is basically the same set up in honda automatic clutch trikes ( i would think so anyway ).
    should a easy ( kinda exspensive little part ) if you get a manual to follow and guide you.
    john
    Feb 2005
    Canada
    663
    Exclamation
    but when i give it more fuel it stops creeping but idels way 2 slow. I can not seem to find a good fuel/air mixture combination iv been trying forever with no luck. Any more suggestions?
    Feb 2005
    Canada
    663
    Any one else?
    Jul 2004
    minnesota
    689
    try rebuilding your carberatour and then adjusting it from there.
    my trikes:
    1983 honda atc 200x-k&n filter
    2002 yamaha raptor 660r, yoshimura slip on, prm grab bars
    1978 chevy nova, 454 v8, bds blower, 150hp shot of nitrous, full roll cage, a real power house.
    1991 chevy s10 4x4 350v8.
    1986 250sx
    YES its fast NO you cant ride it.
    atckowalski is offline Formerly "aaakowalski" Arm chair racerJust too addicted
    Nov 2002
    Northern Mi.
    516
    I think you need to adjust your auto clutch if it takes off when you pop it in gear.It should sit still when it is in any gear unless your idle is set way to high or you have an air leak somewhere.
    1985 Ytm 225 dr (Black and gold)
    1984 Kxt 250 A1 Tecate
    1981 KLT200a1
    1983 Yt 175
    1985 Atc 350x
    1983 Klt 200 C
    1985Ytz250 Tri z
