Thread: Metal shavings, split cases..
    Jan 2005
    Spruce Head Island, Maine
    893
    i took the clutch side crankcase cover off and amidst the small amounts of oil there were alot of tiny metal filings, where could this have come from, i am trying to take the camshaft and crankshaft off to see if they are usable for the rebuild i am having done to my 85 200x.. thanks for the help, i will probably need alot more help in the next little while of me putting the motor back together...
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Phoenix, AZ.
    6,719
    Take pics as you take it apart if you have a digi cam. Do you need a manual? I can hook you up if you need one.
    Check the kick starter gears to see if maybe that's where the metal bits came from. Should be pretty obvious when you spot the offending part though.
    Jan 2005
    893
    i have a camera its on my cell phone but i dont have the hookup for my computer, but i will get a hookup, ill continue taking the rest of this apart, you already hooked me up with the manual thanks again man..
    Past Rides:
    Richland WA
    808
    Put a magnet to them and see if they are aluminum or steel, thatll help track it down. M' guess is spun bearing. Hope Im wrong! : (
    Oswego, IL
    1,858
    thrust washers on the crank?
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    May 2003
    Shediac, New Brunswick
    1,126
    My guess is cam chain loose, rubbing cylinder casting .. aluminum bits all in the oil rotor and everywheres... thats what mine looks like.
    '84 Honda 200x
    slow restro
