Results 1 to 3 of 3
Thread: 84 R issues
    CuRt is offline New to the board Arm chair racerNew to the board
    Mar 2003
    Temperannce, MI
    66
    Question 84 R issues
    finally got my cases back together got the engine in the frame pull the clutch lever really easy and no let off on the clutch rod is there, ball is there and the pusher thing is there.
    What did I screw up?
    Thanks
    Curtis
    85 Tri-Z flat slide carb, DG pipe, silencer, long rod kit, lots of compression and its mean.
    Aug 2004
    glendale
    89
    did * adjust the slack out of the cable? What shape are the clutches in?
    Mar 2003
    Temperannce, MI
    66
    I didn't adjust anything, when I pulled it apart the lower adjustment was in almost all the way and the lever was too now there both all the way out it works skips alittle bit with throttle oh well still moves.
    Curt
