Results 1 to 10 of 10
Thread: Mother ******
    200xadam's Avatar
    200xadam is offline At The Back Of The Pack Arm chair racerFirst time rider
    Michigan (Britton)
    193
    Mother ******
    OH MY GOD!!!
    ok today i got new piston rings and dowl pins for my 200x motor, i was planning on just putting her back together n riding it... well im allowed to dream, but its impossible for things to go good for me...
    well i put the dowel pins in and i got the piston rings in and everything and had the piston all in and had the cylinder over it and was puttin the cylinder in the motor and noticed that i accidentaly had 2 dowel pins on the same stud..well i thought i would be cleaver and just take the piston off the rod and leave it in the cylinder and just take the whole thing off together so i didnt have to deal with putting the rings back in the cylinder...
    well i was trying to take the clip off of the piston to get the rod thingy to off out of the piston to take it off of the rod. well i didnt have a small enough screwdriver to get the clip off so i had a little nail and was trying to pry it out, well my finger sliped on the nail and it fell out of my fingers and INTO THE MOTOR!!!!
    well i tried for about 20 minutes with a magnetized screwdriver trying to pull it out but i couldnt find it...so it is stuck in my motor somewhere....and i cant find it....and im very upset....
    2000 426Ex
    Too Much In The Motor To Talk About
    +2+4 Axle
    Lowering Kit
    FCR Carb
    !*Under Construction*!
    2005 Blaster
    cb750 4cylinder motor
    Pennsylvannia
    1,147
    That bites. Try one of those telescoping things with the magnet on the end.. it might work. Otherwise your screwed and you have to take the whole motor apart to find it.
    jmack3986's Avatar
    jmack3986 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Lancaster, Ohio
    447
    here flush it out with 2 cycle gas that is what worked when i had that happen. try that and ys a flexi magnet would work to just take it easy. you should have covered the motor it would have been easier oh and did you get the cylinder honed by chance because if you didnt the cylinder has a good chance of getting glazed and blowing like my x did.
    arizona
    550
    that really sucks adam, good luck getting that thing out.
    200xadam's Avatar
    Michigan (Britton)
    193
    why would it glaze?? what would i have needed to get it honed for?? i got the cylinder bored for the new piston n i had an oil leak so i tore her apart n got new rings and got dowel pins to stop the leak...
    ill have to get one of them magnets n try n get it...im so mad at this stupid thing
    2000 426Ex
    +2+4 Axle
    Lowering Kit
    FCR Carb
    2005 Blaster
    Nov 2004
    Waterloo IL
    2,701
    This might sound dumb but what about holding the lower end upside down and shaking it?
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    200xadam's Avatar
    Michigan (Britton)
    193
    lol i was thinking about it but my friend was like i dont really think * should shake it becuase it would prolly just lodge it in somewhere so i was trying to keep it somewhere that it was just sitting so that i could pull it out with a magnet, if it comes to it i just might have to try that...im goona try a magnet first, and if that dont work im goona drain oil and try n shake it out...
    2000 426Ex
    +2+4 Axle
    Lowering Kit
    FCR Carb
    2005 Blaster
    Oswego, IL
    1,858
    you still have oil in the thing? lol. arnt you working on the whole motor? never mind.......
    1985 atc 110 for sale
    new carb
    old trike
    1985 200x
    12.1 piston
    oil cooler kit
    white bors cam
    super trapp exhaust
    uni clamp on air filter
    350x front end
    200xadam's Avatar
    Michigan (Britton)
    193
    OK! I GOT IT OUT!!! i drained oil out of the botton end, then i flipped it over and shook it lol. it didnt fall but it came loose and i pointed a flashlight down where the cam chain goes and there it was sitting against the side, n i grabed my magnetic screwdriver n pulled that baby out. and now i have my motor assembled. but i have no oil so this is just another minor setback lol
    2000 426Ex
    +2+4 Axle
    Lowering Kit
    FCR Carb
    2005 Blaster
    leprogle's Avatar
    leprogle is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2003
    New Brunswick
    345
    I did almost the same thing the other day, when i swapped my clutch assemblies. the manual says to put a copper washer or penny, in the gear to keep the crank and clutch from moving while getting the centrifugal clutch nut off, I dropped 3!!!!! pennies in my oil pump!!!!! i blew them out with an air compressor, they flew out the first few blows.
    glad to hear you got that nail out!
    Caution
    Do not "POP WHEELIES" and run for any distance with the ATC. The oil capacity is relatively small and the oil will drain out of the oil pump area thus causing loss of oil pressure, resulting in costly engine damage -CLYMER
