Results 1 to 3 of 3
Thread: 200x axle problems
    May 2005
    Bloomington, MN
    112
    200x axle problems
    do any of you know how to get the rear axle out of the swing arm. i dont no if it matters but its an '83. i just cant ifigure it out
    May 2004
    New Zealand
    129
    Take the two locking nuts off the disc side. Unbolt the disc from the mount and remove. Gentle tap the disc mount off the spline. Then tap the axle from the disc side and remove from the sprocket side.
    Depending on how long it's been in there, it might be tight!
    I take the sprocket off too. Basically strip the axle right down to minimum so it's easier to handle.
    jmack3986's Avatar
    jmack3986 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Jan 2005
    Lancaster, Ohio
    447
    also leave the bolt on when taping axle you dont want to mushroom axle.
