Results 1 to 7 of 7
Thread: 200x CDI problems?
    Arnold's Cove, Newfoundland
    15
    200x CDI problems?
    hey i got the ol' x back together timed and stuff. She wil idle perfectly but when you gives her the gas she spits and sputters alot. If you bared it she almost shuts off sputtering really bad would this be the cdi getting bad?
    Howdy's Avatar
    Celina, Ohio
    10,079
    15
    Yeah i tought of that but their is a very week spark on the plug to and its a new one.
    Howdy's Avatar
    Celina, Ohio
    10,079
    Quote Originally Posted by '83200x
    Your weak spark is probably caused by your exciter coil going bad ( most common problem on 83-85 185-200 cc Honda motors ). Start by testing the exciter coil ( part of the stator ). It's the black with red striped wire coming from the stator. 215-240 ohms is Good, the lower the number the weaker the spark.
    Howdy
    Richland WA
    808
    This is typical of a teardown / rebuild that distubs a bad connector, my Honda 250R did this (orange spark, real hard to start) due to a loose pin in the big CDI connector.
    Or a loose ground terminal.
    Or leaking intake valve.
    You didnt do anything in engine work to cause a CDI to fail.
    Put a timing light on it, use a powered light running off a car battery or 12V battery charger.
    Check the timing at idle, then whack the throttle and see what the timing does. Also, shine the timing light into the carburetor inlet, if theres a blowback from a leaking valve, the timing light will show the fuel coming backwards.
    15
    I got her going perfect now. Their was a loose connection from the stator wires. plug them in nice ang snug and it ran perfect. Thanks for the help.
    Richland WA
    808
    'atll do it every time! Especially when youre 3 miles from the truck!
