Results 1 to 10 of 10
Thread: Valve clearence for 84 200S
    Jan 2005
    Slatington PA
    4,372
    I need intake and exhaust.
    For the X it is .003 intake and exhaust, the S too? I assume too that you put it at the "T" mark just like the X also.
    Thanks!
    Sep 2003
    Brookville,PA
    1,408
    Your correct on all your guesses, just did one last weekend.
    leroy, new york
    1,025
    .002 thats what it says in the book.
    Jan 2005
    Slatington PA
    4,372
    I can't believe they have such a small tolerence like that! Not the easiest to get a feeler guage in there either. I opened it much farther to get guage in and then slowly tightened down till I felt a bit of drag.
    My CRF 450 is 7 intake and 12 exhaust I think. Guess that's cause it gets much hotter then these small motors and the tolerence changes more.
    Opelousas, Louisiana
    1,337
    .003 .............
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    Richland WA
    808
    Set it and then check it when the engine is hot, every motorcycle engine Ive owned loses clearance as the engine heats up, I ended up setting them with the engine running and up to full temp, always ran better that way.
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by TeamGeek6
    Agreed (I never did it that way though) BUT don't you think the factories take that into consideration?
    Richland WA
    808
    The "factory" does not care about us working on an engine, they are in business to sell new vehicles. We have to do whatever makes an OLD engine run the best, and that is the experience I write about, whatever makes the most power.
    Stock valve settings are OK for a new engine, but when the valvetrains wear, that all changes.
    Mar 2004
    Eastvale, CA
    630
    I disagree. If the factory didn't care about it's products, new or old or how long they last, they wouldn't last as long as they do and in turn, they wouldn't continue to sell millions of new vehicles 20+ years later.
    I do agree that as things wear, adjustments need to be made to compensate for that wear until it gets to the tolerance that is no longer acceptable and the manufacturers' tolerances are a lot tighter than the end user's are 90% of the time.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Jan 2005
    Slatington PA
    4,372
    Quote Originally Posted by Mr. Sandman
    I'll say! If we listened or serviced them to their specs, we'd be replacing 1/2 the machine every few years!!
    I will have to try that just for experimentation sometime..........see if I gain 5 horsepower
