Results 1 to 10 of 10
Thread: 200x fork rebuild
    Eastern Long Island
    1,688
    200x fork rebuild
    I am going to be rebuilding/resealing the forks on my 86 200x and have a few questions. First, how much oil should be in them and what is the proper way to fill them? Also, what is a good starting point for the air pressure? thanks in advance.
    Aug 2002
    Creswell, OR
    889
    Standard air pressure is 0 psi....the more air in the stiffer they are....I do not remember how much oil (sorry). Very important when you get started..After draining oil you need to remove that bottom bolt.....Mine were set in there with locktight....therefore spinned once broke loose, but would not come out. Air compressor very strong one, impacting work best. I actually was able to mooch a shop to impact them out.....No I did put the bolts back in with locktight. When you get to this point, If you have trouble getting the seals out themslves I know a cheap trick to get them out. Good luck Jen
    Aug 2002
    NY
    2,652
    you lame arse turd i told you i would help ya out. if your gonna cry about it all day i am going to go postal!!! good question about the oil though. my Z had just under 12 oz. and dont bother adding air i dont have any in the Z.want me to come over and hold your hand to fix them?? maybe you should stick to breaking boats i mean fix them whoops!!! hehe later
    Jonathan is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    200xman, are you the same 200xman that used to come to the old board with the 86 200x with the messed up transmission/clutch?
    I like motorbikes!
    Nov 2001
    B.C.
    933
    If you are looking to stiffen up the fork action, air is NOT the answer! Use a higher viscosity oil in the tubes.
    Join The Trike Registry Now!
    http://fly.to/TrikeHeaven
    Eastern Long Island
    1,688
    Johnathan, I am a completely different 200xman. As for everybody else, thanks for the replies. I resealed them last night and everything went smoothly(thanks Mike). Now all I need to know is how much oil to put in them. Anyone know :?: :?: :?: :?:
    Dec 2002
    SW Alabama
    763
    For 86 200x use 7.3-7.5 oz. SAE 10W. This is according to the Clymer manual
    Trikes: Cagiva 200, 85? Tiger 250,(2)84 200x's , (3)86 200x's, 87 200x, (5)85 350x's, (2)86 350x's, (2)85 250r's, 86 Tecate, (3) 85 250sx's Restoring: 83 200x, 86 250sx. Too many utility trikes to list.
    Eastern Long Island
    1,688
    Finally, A light at the end of the tunnel. Hopefully I will have a rolling chassis by tonight. :-D :-D :-D
    Aug 2002
    NY
    2,652
    i am god and man it took me a half hour to get that pizza last night in the snow!!!! had to drive with the truck in 4 high!!! slipper as all hell dont forget about the meeting tonight at riverhead honda lol later
    Feb 2003
    California
    623
    high/low
    lol lol wouldn't you get more traction in 4 low, 4 high is the same as 2h but the all wheels are driving, 4 low gets you more power and better traction. lol lol
