Help
Ok i bought new bearings for my 82 ATC 250R because the rear axle was wobbling left and right. I tried tighting it up like someone mentioned but that didn't work. So I took the axle off and the bearing looked fine. So what I did was slid the new bearing on the axle and they don't fit snug either the wobble to the left and right. Could the axle be bad (worn)from it's original diameter or could it just be the wrong axle on the bike? Help me out with this please.
It could be a wrong axle. But most likely the axle is worn where the bearing sits.
Howdy
I'm going to check back with they guy I got it from tomorrow. He should have some extra axles around.
//ArrowChat Integreation Code
