Thread: Big Red 200E Help
    May 2005
    Edson Alberta
    15
    Big Red 200E Help
    I recently got this 1983 Bigred 200E for 400$ Canadian.
    I took it for a 2 hour trip and the chain broke off whats the easist way to put a new chain in?
    Another thing i can't keep the hubs on tight on the rear. I'm using these big Super Swamper Vampires That work awesome. Any help on this would great becuase once it loosens off you can feel it wobbling around quite bad climbing hills and doing donuts. EDIT - I have also tried blue locktite
    Also where can i find some parts for this other then Ebay
    I know of Bike Bandit and Dennis Kirk website any others?
    So far i am really impressed of this bad boy machine goes throught the muskeg and goes through the mud.
    Thanks Alot
    Mike
    FIRST POST WOOHOO
    Jan 2005
    Great Bend
    704
    if you are gonna replace the chain replace the sprockets as well. if you put a new chain on old sprockets the sprockets will start to loose teeth. chain and sprockets work themselves into a wear pattern to each other and if you put a new part on an old wear pattern(i.e. new chain on old sprockets) things start to break repeatedly.
    to keep the rear hubs on get a mid strength thread locker and apply the day before you go riding so it has a chance to set up and get a secure hold on the threads and you shouldn't have anymore problems with wobbly hubs.
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    +2" Miltech swingarm
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    +1" Miltech swingarm
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    May 2005
    Edson Alberta
    15
    Thanks ATCWRENCH
    My dad told me to replace the sprockets to he said atleast the rear one.
    Itsn't Thread Locker the same as Locktite????
    Correct me if i am wrong.
    Thanks
    Mike
    Jan 2005
    Great Bend
    704
    yea if it's any kind of locking compound for threads it will work.
    here is a chain and sprocket kit on ebay for a fair price 4566594548
    I couldnt post a link its the auction number
    1985 KXT 250
    84 KX cylinder
    sprock racing head
    frame mounted Rad
    1983 250R
    DG head
    290cc Big Bore
    CT pipe
    85R front end
    2+2 axle NOS NASA
    18x10x9 Hoosiers
    darrel632 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    alberta
    429
    Try "Recycle" is Spruce Grove for parts or Snowmobile Heaven in Rimbey (843- 3654), the bargain finder paper(edmonton) also is a reasonable parts source.
    Darrel
