Results 1 to 12 of 12
Thread: Expected power from a 660r
    Lenox TWP MICHIGAN
    79
    I got a 660 raptor and i have a jet kit alba pipe and k&n filter and it is really fast or seems to be. It makes around 45 HP and i was wondering what type of gains can i expect to get from a std bore 11:1 weisco piston and a web cam stage 1 cam put in. Just curious to see if its worth my time and money.
    May 2002
    Southeastern Wisconsin
    3,658
    Quote Originally Posted by Modded660R2fast
    There is absolutely no chance you are making that kind of power with those mods. If your lucky your making high 30's. With an 11:1 and a stage 1 cam you might get into the 40's.
    Lenox TWP MICHIGAN
    79
    ok but anyways how much would these mods give me. The cam and 11:1 piston
    Lenox TWP MICHIGAN
    79
    if you go to www.ctsonic.com they have all the dyno runs of the jet kits, pipes and filters they used on a raptor and they show all the hp gains from a huge selection of different brands of pipes so that is where iam getting my number.
    Lenox TWP MICHIGAN
    79
    sorry www.ctracing.com my bad and let me know what you think
    Jan 2005
    Paris, Tx
    117
    your rite * should be around that figure plus or minus 2 or 3 hp. The piston probably wont do much but from what i hear the cam makes a big diference although ive only heard about the hotcams cam.
    Current Bikes
    02 Drag/Dune Banshee
    84 ATC 110 -4 SALE
    84 200S- all original other than tires!
    85 Tecate (need motor)
    Former Rides
    03 660R- R.I.P.
    85 Tecate 3 Nice!- Sold
    82 250R -Sold
    Jun 2003
    englishtown NJ
    2,676
    pipes on raptors make a huge difference, dirtwheels had some number like almost 8-10 horses with just a pipe and pro-flow airfilter kit(tosses the lid), a raptor is very choked up stock.
    Lenox TWP MICHIGAN
    79
    Is there any other ways to make some more power out of my raptor. I woluld like to think of it like this, what exactly does a yfz 450 have that a raptor doesnt (engine and tranny wise) to make it go faster. Does it have a high comp piston or huge cams or what ever. Cause i figure that if i get exactly what the 450 has done to its engine such as high comp piston huge cams port and polish etc or whaterver. I figure whatever the engine has that make's it make so much power, Then have it done to my raptor, then since i have 210 more cc's then the 450, Then since i have everything that the 450 hassuch as engine mods, then i should be able to smoke all kinds of bikes right. Think of it like same bikes just one bike has a bigger engine but both engine's were built the same but just with bigger components. Does that kind of simplify it some i hope no ones confused and let me know what you think.
    Jan 2005
    Paris, Tx
    117
    the comp and piston size is the main difference between the 2. Also the stroke is smaller in the 450. if you really want to beat one. Send the motor to craycraft and have a 686 kit done with port and polish. He also adds a stage 2 cam with new springs and retainers. Ive seen a craycraft 686 bike run and it was fast as hell and then i saw dollarbillz 740 craycraft raptor and theres nothing close to it. No trike ive every saw would come close to that bike period! but ont theother hand small motor bike weigh less and seem to always sream especially when it come to 2-strokes. stock for stock banshee vs. raptor the raptor will kill it, but pipe and jet both of them and the banshee will come out on top. If you wanna go fast its pretty simple sell the raptor and get a banshee! or if * wanna be on three wheels get a T3 or 250R
    Current Bikes
    84 ATC 110 -4 SALE
    Former Rides
    03 660R- R.I.P.
    82 250R -Sold
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    raptors are pretty impressive bikes, I have a riding buddy, with alba intake, jets and looneytunes dual exhaust and he hit 84.7mph on my gps on asphault. I'm normally not a raptor fan myself.
    I woudld tend to think for the money of a cam and piston there would be more of a gain in shedding some weight. get some fox floats and if you ride in dunes remove your skid plates possibly lights etc. It all come down to what your willing to loose but when I got 50ibs off my scrambler 2 pounds at a time it made almost as large a difference as my pipe. Just trying to give an idea you may not have considered.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Lenox TWP MICHIGAN
    79
    How big of a difference will i see if i got a cam in my raptor?
    Dec 2002
    172
    my friend has the same mods as you currently, and then put in the stage 1 hot cam. it increased the power across the rpms, but especially in the low and midrange. it hits kind of hard now. seems to spin the tires alot more too, you should run good tires. one thing with the raptor, it seems alot of people i see overrev them. the motor peaks around 6500, so you should gear the bike high to keep it pulling in the meat of the torque curve, and ride a gear high in the turns if you can.
