Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Thread: Stretching an airbox boot
    Phoenix, AZ.
    6,719
    I can change the main jet and clip by just turning the carb on an angle a little bit. If I stretched the thing over the carb the way it's been it would have been so tight I doubt it would have even turned without taking the airbox off so the hole boot could turn with it. I damn near changed my pilot jet when I went to Cinders though. I resisted the temptation but that's the only way it would have ran completely right up there. That 7000 feet elevation is a PITA.
    Bottom line is, I just want the stupid thing to go on and off easy.
    I think the repeated heating and cooling is working. I'll try putting it on in the morning and see how it goes. I just hate the idea of having to take it off on the trail (for whatever reason) and not being able to get it to go back on. Hell when I finally got the bike running again a few months ago, that was the hardest part of the entire rebuild was getting that damn thing on there. And that was with the stock carb!
    I checked out the one KASEY has on his 500R and mine is definitely way stiffer than normal. Unbelievable pain in the neck to work with. Really aggrivating for such a stupid thing. It's in great shape other than that. No cracks or anything.
    Quote Originally Posted by hrc85250r
    dude, just have someone push the boot towards the carb for you while you work it on with a screwdriver....i have my pops help me out and it takes 1 minute max...i dont even lube it up or anything, and i dont even scratch or rip the carb or boot...just dont be a puss with it...o ya, i have a 38 a/s.....
    I live alone and never have anyone around when I'm working on my trike. I'm telling you guys this boot WOULD NOT go on a 38mm carb before I started doing this. I couldn't even get it to go on when the carb was off the trike. It's not all soft and rubbery anymore. I'm sure it would have been easier with an extra set of hands but I'm not gonna have somebody drive over here to help me with something so little. If I can't stretch it to the point that it slides on and off there easily I'll just keep using the clamp on and steering around puddles.
    Mar 2004
    Eastvale, CA
    630
    , Maybe you need to drink another brand of beer! Seriously, I used an MGD bottle and had no trouble with mine at all. Or, if you have the time, pull the carb and boot completly off and put it together off the bike. This way you can do it easily and then let it set for a week or so and hopefully by the time you try to remount it, the boot will have the new shape/size it needs and will assemble easily.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Phoenix, AZ.
    6,719
    Done!
    Corona bottle + heat gun = A WINNAR IS ME!
    Slips right on now. No fighting with it at all. I even had it off the bike and without the bottle in it for about an hour and it held it's new shape and went right back on again.
    So much trouble over such a dumb thing.
    Edit: for people using the search in the future, all I did was grease up a corona bottle, put that into the boot (neck first), used the heat gun on the 1000 degree setting to get it almost to the point of melting but not quite. Let it cool down to room temp, then stick it in the fridge for a while, then back to room temp and then heated again. Rinse, repeat. Did that three times.
    nimda78's Avatar
    nimda78 is offline At The Back Of The Pack Arm chair racerFirst time rider
    coeburn va
    177
    great closing! great info too
    -1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
    -1986 kx80- S O L D
    Richland WA
    808
    Try heating it in an oven at 175*F - 200*F, that will heat it evenly so it doesnt tear. Most plastics dont like more than 250 - 275*F
