Results 1 to 15 of 21
Thread: oiling UNI air filters (quick question)
    Opelousas, Louisiana
    1,337
    on a atc 110 i have a uni it has a inner yellow layer and red outer layer.
    Do I have to oil the outer and inner layer or just one?
    I havent cleaned it in about 2 years and i dont remember what i did last time.
    1986 350X K&N filter, DG Krome Power exhaust
    1982 110 UNI filter, Cobra megaphone exhaust
    1982 honda 110 exhaust for sale, PM me.
    nimda78's Avatar
    nimda78 is offline At The Back Of The Pack Arm chair racerFirst time rider
    coeburn va
    177
    id think if ya washed both, you would oil both. ive never had outters for my pleated k&n filters tho. just a good guess
    -1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
    -1986 kx80- S O L D
    wheelie king's Avatar
    wheelie king is offline Aficionado of white surprise sauces. Arm chair racerRoostin Away
    Central FL USA
    1,174
    Put oil on the outside of the filter, and massage it in. Wipe any excess. You're done.
    1986 Honda ATC 200 S
    Some quads and a S x S
    Supporter of Uncle Rico's football camp. Since 1982.
    If you are reading this in English, thank a U.S. Military VET. ΜΟΛΩΝ ΛΑΒΕ
    NE Arkansas
    2,344
    what kind of oil? i'm in the same boat, both my trikes have UNI's.
    My Rags
    nimda78's Avatar
    coeburn va
    177
    Arrow unifilters.com
    heres what their website says. i didnt see it say "not" to oil the inner, so doit toit
    uni filter care
    -1986 kx80- S O L D
    NE Arkansas
    2,344
    what other kinda (common type) oil can be used?
    are they dry when they are new in the box? K&N's come pre-oiled.
    i put mine on the way they came outta the box. hope i haven't messed up, cause it's been on the 200 for over 2 years.
    My Rags
    Antioch,California
    149
    Uni's come dry. You need to oil the inside(yellow) and outside (red). I use PJ1 sticky spray on oil, its red.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    The PJ1 works great. Use to use bar and chain oil, but the PJ1 is much stickier and stays on much longer.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Phoenix, AZ.
    6,719
    Uni makes their own oil as well as their own cleaning agent.
    1,337
    yeah trav you are supposed to oil them when you get em. it says so in the package!
    i have some klotz foam filter oil and some pj1 foam filter cleaner.
    you get a lot better value with these brands than with uni. twice as much of each for the same price!!
    G-MAN-1 is offline Just Too Addicted Arm chair racerJust too addicted
    lol
    you do not have to oil the yellow one. only the outer one.i know ive been doing this for 20 freaking years. why oil the inner so you suck all that sticky **** in the carb (NO). clean both but only oil the outer one.
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    How can you squeeze the oil thru the outer without getting oil on the inner?
    Its going to get in them both wich is better any way. The course outer red part is going to catch the bigger particles of dirt. and the finner inner, yellow with the oil on it will catch the even finer particles of dirt/dust.
    Same with a mower foam filter you oil it to catch the fine particles of dirt/dust from going into the engine.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    Jan 2005
    RI
    2,530
    i use my k & n oil on my unifilter
    Antioch,California
    149
    UNI says to oil the inside(yellow) and outside (red). Evan if you only did the outside, dont you think the oil gets to the inside anyway?
    Proper way is to soak or spray both, Work it in, then squeeze the excess off.
    1,337
    I sprayed oil on both and squeezed out the excess.
    After I did that I got a reply from UNI on the email i sent and they said to oil both.
