Thread: 1985 honda 250 fourtrax problem
    cambridge mn
    4
    I have an old 1985 fourtrax 250 that has a bogging problem. It runs great at idle to 1/4 throttle. Anything after 1/4 throttle, it boggs down and if I hold it, it dies. If I run it like that for long, the plug will foul out and it wont start.
    Any help would be great!
    Thanks
    leroy, new york
    1,025
    Clean your carb and check gas lines sounds like you are not getting any gas, when you hit the trottle.
    Try running it without your gas cap, my vent clogged up and would cause that problem. you might also check the filter in the tank.
    1985 350x
    1985 350x
    1985 250r
    200 auto x
    1984 250r
    1982 250r
    85 Tecate
    86 Tri Z
    85 TRI Z
    98Wolverine
    99TRX 300
    Jackson MI
    1,688
    Make sure you are getting enough air to the carb. If it fouls the plug, (turns plug black & soaks it with gas). Then pull the air box cover off & try it again, with a new plug. Make sure the choke is opening up, & the air filter is not plugged. If the plug isn't wet then clean the carb, especially the main jet. If it idle's good the pilot jet is ok.
    cambridge mn
    4
    I just rebuilt the carb. New gaskets & jets. Same size that were in there and that did nothing. Also have new fuel lines and filter. I will check the vent in the tank cap. Thanks
    Richland WA
    808
    What jet sizes are in it? Sounds like the main is too large or needle too high. The stock carb setup for the '86 ATC250R is here:
    http://www.3wheelerworldforums.com/s...026#post259026
    See how your carbs jets compare to that list, should be ballpark.
