Results 1 to 2 of 2
Thread: Installing Flywheel
    Brandon, Manitoba
    2,209
    Installing Flywheel
    I had the flywheel off on my YTM, now I've replaced the cam chain and I tried putting the flywheel back on, It butts up against the idler gear but I can pull it back off with my bare hands, Is this normal? Does it eventually seat or something?
    I was thinking it might be that woodriff key. I read in other threads it can get sheared, but mine looks fine.
    Richland WA
    808
    If its a tapered shaft, itll come off by hand until its bolted down, then the roughness on the 2 surfaces lock together. I gave up on using a key, it doesnt do anything unless the crank locks up then it prevents it from twisting.
