Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: no torqe on my 84 125m HELP!!!
    zoomerman's Avatar
    zoomerman is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Ontario, Canada
    351
    Exclamation no torqe on my 84 125m HELP!!!
    hey i picked up a 1984 125m for 400 candian therew was no battery or igetion
    i got the igetion but the honda dealer messed up and i still don't have the battery well this machine has no torqe at all it won't make it up a small hill i need help it's crap if anyone can help thanks.
    springville, PA
    6,185
    You mean torque? does it seem like the clutch is slipping perhaps? It is still reving correctly right?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Pennsylvannia
    1,147
    Maybe you have it in 5th gear trying to go up that hill? Try downshifting..
    leroy, new york
    1,025
    Quote Originally Posted by nouseforaname90
    I thnk he is right! LOL
    zoomerman's Avatar
    Ontario, Canada
    351
    the engine runs fine and i have to click it into low to drive it. and if i drive it for more than five minutes then it's doesn't even really move but it runs fine.
    Jul 2004
    Mud hill. close to water !
    3,658
    Clutch...........
    That little guy will wheelie with a good clutch...
    Currently :
    Yea i have a 84 125m and it has no problem with hills or wheelies its a tough lil sucker,id look into the clutch.
    1983 Honda 110
    1967 Mustang
    zoomerman's Avatar
    Ontario, Canada
    351
    k thanks i'll take the clutch apart tonight
    Poplar, WI
    531
    I second everyones opinion on the clutc. I had somewhat the same prob. you mentioned, and It runs like a million bucks...they're tough lil buggers LOL
    1983 250R ~ 1984 125M ~ 1990 POWER WHEELS!! trike
    springville, PA
    6,185
    Quote Originally Posted by zoomerman
    Just try tightening it. On most auto clutch machines you can tighten up the centrifical clutch.
    Nate
    R.I.P HRR
    zoomerman's Avatar
    Ontario, Canada
    351
    the clutch is almost tightened all the way well i'm going out now and taking it apart
    zoomerman's Avatar
    Ontario, Canada
    351
    i tightened the clutch all the way witch was only like a half turn so i think the cltuch is worn like crazy
    springville, PA
    6,185
    most likely. your goin righty tighty right?
    Nate
    R.I.P HRR
    Jul 2004
    3,658
    IF it's like the 200cc series.. you should go counterclockwise until it stops.. then go in x amount to set the clearance.......... are you sure you did it correctly ?
    Currently :
    zoomerman's Avatar
    Ontario, Canada
    351
    oh i thought * go clockwise when it gets loose
