and don't forget this is the 200cc models.. but after backing out all the way.. you go in either a 1/4 or 1/2 turn depending on the models.. ... ..... so it's not much.
then you lock it down with the outer nut.
Currently :
84 125 M - The Mini-SXnot running yet. but won't be long.
oh i get it yeah i did it right but it still doesn't have any power so i'm going to take the right crankcase cover off and look at the clutch
1985 suzuki alt 185
1985 honda atc 250sx
1985 honda atc 200m (all apart)
1984 honda atc 200es
1984 honda atc 200x- need motor, plastics, axle, exhaust.
1984 honda atc 125m- times 2
1985 honda atc 200m all apart
1983 honda atc 200e times 2
1983 honda atc 250r-times 2
1983 honda atc 200 4 parts
1983 honda atc 110 times 3
1979 honda atc 110 smokey
1978 honda atc 90- restored
Have lots of extra parts, if interested email at e_mcy@hotmail.com
I have an 84 and I pulled my tractor out of a mud hole with it with 2 flat tires. Its got to be the clutch, is it revving high but still not moving? Allso you could be losing compression or it could be sucking air. Check that out after the clutch. Can you go through all the gears? Allso check your clutch cable and clean your Air Filter. Look for clogs maybe. Thats all I know to do from here. Good luck. Dont give up the Honda 125 M is a great little Trike.
84-85 Custom Tecate
1986 Honda 200X Daily Rider
2006 Suzuki King Quad
the engine runs fine and i did a compression test on it and it had about 140 psi thats ok right??? i can go through all the gears but it doesn't shift right half the time
1985 suzuki alt 185
all that really does when the engine is cold is take the weight off the tire for a second but i can't get the crankcase cover off two scews r on there tightly!!
1985 suzuki alt 185
With those phillips screws... IF you are lucky you can sometimes take a dremel tool with a cutting disk and cut a groove for a flat-head screw driver.
Use a socket with a flat head bit so you can really push on it when you twist.
Currently :
yeah there phillp screws thanx 4 the idea!!
1985 suzuki alt 185
I've had good luck removing those screws with an old fashioned "impact driver" with a large philips bit installed. Don't hit it too hard, but it worked for me on my 90 and 110.
'70 US90
'77 90
'85 110
yeah thats wat i've used before 2
1985 suzuki alt 185
I think mines due for a clutch also it is hard to get into gear sometimes.
1983 Honda 110
1967 Mustang
do i need the whole chutch or do * think it's just the clutch plates
1985 suzuki alt 185
if the basket is fine, and the stee plates arent heat fractured, yes..all you need is the fiber clutch plates. soak them in oil 12-24hrs before * install them
-1983 Yamaha YTM200K chain drive -3rd owner! -UNI dry foam performance filter /w wet outterwear -RM 125 2" rise steel handle bars in black powder now - bent from a rolloverCustom 2" round LED tail light /w stainless steel trim in aluminum mount Custom polished aluminum diamond plate rear fender brace with Stainless steel hardwareStainless steel Torx mudflap bolts Custom ONAN vtwin muffler TOUGH sound
-1986 kx80- S O L D
hey i got the right crankcase cover off but i can't get the clutch apart the two scews are striped a bit
1985 suzuki alt 185
if * have extra screws * can drill um out if worst comes to worst. or use visegrips they can do just about anything
