Thread: Long Travel 250R
    Mar 2004
    North Central Ohio!!
    2,712
    Long Travel 250R
    Looks like i've got everything I need to add the CR500 suspension to the 250R.
    I'll get some pictures up when I get it together. I still have to get my second set of triples machined out to hold the 500 forks.
    I decided to try this out after staring at the tiny looking 250R sitting beside the 500. I also wanted to see how the 250R would compare to the newer quads with equal suspension. I should end up with 12+ inches of suspension front and rear after the conversion.
    Best part is, so far it was really cheap. I picked up my forks for $16.50 (that are in great shape) and just got a custom Ohlins rear shock for $50! Only expense left is the machine work.
    I'll start another post when I get some pictures but i'm pretty excited about it!
    Dec 2002
    749
    Derrick sounds like your making some awsum progress. Whered you get your Ohlins for 50 bucks? I just got a brand new custom Ohlins also for my 426. Cost me 125.
    3WheelsForever / Virgil
    TrikeFest 03, 04, 05, 06, 07
    1985 Honda ATC350X - TF2015 Project
    YZ426 Hybrid Trike - On the back burner
    springville, PA
    6,185
    Wow $50 for a rear shock! does Ohlins have a website? Sounds like you getting some steals too. How long before she is done?
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Mar 2004
    2,712
    Bought that shock off ebay. Seller didn't know what he had. I wouldn't have either except for I have the exact same shock on the 500. It's used, but supposedly in good shape. Doesn't really matter too much, i'll probably have it gone thru anyhow. It's actually $650 new.
    I would like to have it done before the September races. But, it's taken a month for the machining on the 500 triples, so who knows.
