Results 1 to 15 of 61
Thread: 200X: Hard starting
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    200X: Hard starting
    My 1985 200X is tough to start. I've rebuilt the carb and adjusted valves a few times. Neither of those really helped. I swapped over a spare coil and CDI I had...no dice. Last night, I check the resistance on the exciter coil and the pulse generator. Both read fine....so good infact, it was like I was touching the two leads of the multimeter togehter. I checked the resistance on both coils I have and they checked out fine. The sparkplug is gapped correctly.
    I really don't know what to do now. Any ideas?
    1985 200X
    Pa.'s Highest City
    8,058
    http://www.3wheelerworldforums.com/s...ght=200x+spark
    There are many threads about this particular subject on the boards. Do a search... If you don't find what your looking for just ask!
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Thanks. I've done a few searches and tried just about everything. I'm not sure what to test/adjust next.
    1985 200X
    Pa.'s Highest City
    8,058
    Well if it makes you feel any better I'm in the same boat as you!
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Quote Originally Posted by chrisr200x
    LOL! I'm glad I'm not the only one.
    1985 200X
    Richland WA
    808
    Fouled plug, too lean on idle or bad wiring in the ignition system (the most likely). I had this exact problem (had to kick my leg off) until I found a loose terminal on the CDI plug. Since I fixed the wiring it starts in 1/2 kick on a good day.
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    How about too rich when idling? This thing idles really low when it does start and does not like to be given any gas for about a minute or so. Once it's up to op temp, it idles a bit high.
    1985 200X
    Jul 2004
    Mud hill. close to water !
    3,658
    Glenn.. that sounds to me like normal operation.
    Currently :
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Well, at least that kinda helps scratch the carb of the list of problems.
    1985 200X
    Mar 2005
    Alberta
    503
    I'm not familiar with 200x's but I have had similar symptoms with some of my other Hondas. Usually I tracked the problem down to an air leak on the intake system. Either on the intake into the head or believe it or not on a couple of them it was the rubber boots that seal arond the top of the carb where your throttle cable and / or choke cable go in. Mine would idle too slow when cold & too fast when warm. Just an idea.
    A whole bunch of trikes.
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    That's good to know. I'm going to check the intake system with some propane and see if there are any leaks.
    1985 200X
    Richland WA
    808
    That wont work unless the AF mixture is a tad lean, if its already too rich, propane is just more fuel on top of fuel.
    Mar 2005
    Alberta
    503
    Quote Originally Posted by TeamGeek6
    Yeah but any noticeable difference in the idle while doing this would indicate a leak in the intake system. Ether works better than propane, BTW.
    Apr 2003
    394
    Quote Originally Posted by Glenn J
    Glenn, did your carb kit come with a new slow jet and idle screw? I know alot of kits do, but I've seen so many partially plugged slow jets to trust them.
    I see that honda did a service bulletin for hard starting cold on a atc250es that called for a different slow jet. http://www.3wheeler.org/tech/06161-H...STRUCT1_50.jpg and vent hoses http://www.3wheeler.org/tech/06161-H...STRUCT2_50.jpg
    I had two 200x's at one time. One had the same problem, boy I ended up just hating that X, because it would'nt fire. I hope you get your fixed. Good luck.
    Hey, maybe swap on another carb to test? .................
    84'R pic page; http://magoos.wheatfarm.com/pictures/index.php
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Awesome Troll! I should try the slow jet. I don't think I replaced that...I wasn't sure of the propper way to remove it. I'll give that a shot. And I have a spare carb that I can try as well.
    1985 200X
