Results 46 to 60 of 61
Thread: 200X: Hard starting
  1. #46
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    Thanks Jenn! Maybe I'll just get a new slow jet and take it from there. I rebuilt and cleaned this carb about 8 months ago, but maybe I'll pull it and take a look at it again. At the very least, I think I'll toss in a bigger slow jet. The dealer should have those I think....
    1985 200X
  2. #47
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    I pulled the slow jet out of a spare carb I have. It's labled "40". I'm going to hit the dealer today and see if I can get a 42 or 45.
    1985 200X
  3. #48
    Pa.'s Highest City
    8,058
    Be sure to post and let me know how this works out for you. I'm still tweaking my carb as well.
  4. #49
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Will do. I'll probably get into the carb tomorrow morning. I'm doing some riding Sunday.
    1985 200X
  5. #50
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    It's one thing after another! LOL!
    I can start it, but I can't get it to idle correctly. I put in a 42 slow jet, stock is 40. The trike starts pretty easily now, even when hot. However, I can't set the idle correctly. It's either too high, or way to low and stalls out. The different between the two is like 1/16th of a turn on the idle screw. I'm kinda stumped.
    1985 200X
  6. #51
    Mar 2005
    Alberta
    503
    Quote Originally Posted by Glenn J
    Pull the carb slide & have a look where the idle screw contacts it, there might be a gouge on it or a wear spot. This makes the idle hard to set. Using a small file & some patience you can smooth it out.
    Also, check the idle screw for straightness or a buggered up tip on it.
    You're sure there are no air leaks antwhere? They can also cause idling problems.
    A whole bunch of trikes.
  7. #52
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    I'll take a look at the slide, I hadn't thought of that. I'll double check again for leaks just in case. Damn carbs! I see why fuel injection is getting popular.
    1985 200X
  8. #53
    Des Moines, IA
    1,303
    My 200x that I've been complaining about has a big gouge on the slide too. I've been thinking about taking a Dremel to it to see if I can smooth that out and make it possible to adjust the idle...
  9. #54
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    I hope to pull the slide out Thursday for a look.
    1985 200X
  10. #55
    May 2002
    610
    I would Fix the grooves in the slide. On my trike I have just given up on getting the idle right for all conditions... Can you reach the idle adjustment screw from your riding position?What I do is. when cold use choke and kick it up.. use the throttle to get it going and adjust the idle screw for smoothe idle...as it warms up I let the screw out for smoothe idle...as I ride sometimes when I stop it needs a little fiddle to stay smoothe. I have a custom carb and everything else and this works like a charm. Once you get used to these small adjustments it will run ok.
    Sam from Florida
    1985 BIGRED $ 200X
  11. #56
    May 2002
    610
    Oh also the slow jet has to be in the right range! I have not read all the posts here but I know on my stock carb I needed the next size slow.
    Sam from Florida
    1985 BIGRED $ 200X
  12. #57
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    I messed with this a bit today. I backed out the pilot screw to fatten up th e mix a bit. However, I'm still getting some "hanging" when I rev the engine; the idles doesn't drop right down to idle, it takes a few seconds. I'm kinda lost... I'm running a 42 slow jet vs the 40 stock.
    1985 200X
  13. #58
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    My 84 200x had that EXACT same problem. I checked for air leaks for days, rebuilt the carb (all new jets, o-rings, needle, EVERYTHING), adjusted the valves, adjusted the pilot air screw, adjust the idle screw, I did everything. Anyway I got it running to the point where it would idle high and a few seconds later the idle would back down and be rock solid. Last thing I thought to check was the ignition timing and bingo!!! I pulled the c.d.i. cover off on the left side of the cylinder head and the pulse rotor base plates notch wasn't lined up with the notch on the engine (know what I'm talking about, if not let me know). It was only off about 1.5mm, a very very small amount, I guess it had slipped because the screws securing the base plate had loosened a little. Anyway after lining the notches back up everything was fixed...talk about relief after about a week of frustration, anger, and more anger at the damn thing. Now the idle is fixed perfectly.
  14. #59
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    I'm willing to give pretty much anything a shot at this point! I think I'll check that out this weekend. Thanks for the advice!
    1985 200X
  15. #60
    Glenn J's Avatar
    Jul 2003
    Wallyword, CT
    155
    Ok kids! I rebuilt and older carb I purchased awhile back so I may give that a shot. I did notice some "dents" in the grove where the idle screw rests. I should check my current carb.
    I think I'll try the CDI trick solid snake mentioned as well.
    1985 200X
