Results 16 to 30 of 34
Thread: Im trying to Identify the engine in my 200x
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    Hello
    Quote Originally Posted by chrisr200x
    There should be vin numbers on the bottom of the motor by the shifter and the cc # is on the side of the cylinder in the back.
    Then #'s on my 200x are as follows: TBO5E
    5249808
    I'm not to sore about the 1st 8 in the bottom #... It may be a 3.
    He is just useing that as a compsarrison.
    xd 200x is offline Just Too Addicted Arm chair racerJust too addicted
    no clutch. thats not mine, I have pics if someone would give me an email to send them to ,. It dosent have a lever
    springville, PA
    6,185
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Feb 2003
    California
    623
    Oops, sorry. maybe its a 185 or 185s
    sent you my pics thanks
    springville, PA
    6,185
    I got the pics but it might be awile till i can post em (he he dial-up dont like 4 meg )
    Nate
    R.I.P HRR
    springville, PA
    6,185
    here is one pic I was able to get before my comp started being retarded. I had to make it my desktop by the way because when I hit save pic and the picture is already uploaded it will save like instantly, but when i tried it on these it wanted to download them all over again so I said screw it. i'll post more in the morning.
    Nate
    R.I.P HRR
    thanks I know it's a 200 cause of thw 192 on the jug but I just dont know which one
    Missouri
    79
    More than likely you have a 200es bid red motor. Does it have a hi/lo 5 speed tranny?
    Mar 2005
    Alberta
    503
    Looks like the starter is horizontal across the front, right? Rules out 185 , 200s & 82 plain 200 engine.
    Chain drive, rules out 85-87 BR or SX.
    If there is no high / low that rules out 83 BR
    If there is no reverse that rules out 84 BR.
    Auto clutch rules out 200x.
    That leaves us with 82 BR (only because I'm not sure of a sub-trans. on them) & my guess of a 200m. Looks like black cases?
    A whole bunch of trikes.
    springville, PA
    6,185
    ok here are the rest. its not a big red but it has a DG exhaust on it
    Nate
    R.I.P HRR
    Howdy's Avatar
    Celina, Ohio
    10,079
    200x's are 198 Cm and have a clutch on the right hand side. And no pull start. (kicker)
    Chris, the 83-85 200x's were 192cc.
    Quote Originally Posted by trikes4life
    looks like a 200m
    You hit the nail on the head here. That is a 200m motor. No doubt about it. You can use rings or pistons from 200, 200s, 200e, 200es, and a 200m. They all innerchange. Top end gasket kits will innerchange as well.
    Howdy
    springville, PA
    6,185
    oops forgot this one. Nice jump with a 200 motor.
    Nate
    R.I.P HRR
    edog's Avatar
    Mar 2004
    New Hampshire
    6,629
    1983 200m motor for shure.
  15. #30
    thanks guys alot
