I am a firm believer in "repair instead of replace." Any ideas at all on how I can repair this coil for my Z?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
83 YTM 200L For sale,
82 Tri-Zinger 60 For sale,
8? YTZ 80 Conversion,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
If the coil is good but the wire or cap is bad you can easily fix that. You can get replacement wire and a new cap, they just screw on (normal direction threads).
Do I have to get those pieces from Yamaha, or will any plug wire and cap work?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Ah, a cap from anyone should work without much fuss. NGK makes aftermarket caps and I beleive that they offer wire as well, Check with any local atv parts place.
1985 Honda ATC 350X
2003 Yamaha Banshee
2003 Polaris Sportsman 500
There are 3 kinds of people in this world, Those who make things happen, those who watch things happen and those who wonder what the hell happend.
Thanks Will, I did not think of that.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Trim the wire back an inch past the bad spot, solder a new piece of copper or steel core plug wire (Belden makes it, NAPA should have some). Put a piece of tubing over the joint and fill the tube with - YES, JB - WELD !!! - and itll work like a champ. Cure the JB in a warm place about 150*F and itll set up like stone. This is how I extended my 250R coil wire.
JB WELD RULES!![]()
You would not happen to have a photograph of this set up would you?Originally Posted by TeamGeek6
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
Hey Lonesome, have you tried to unsrew the wire yet? If it comes out, splicing would be a bad idea. Instead of splicing in a new cable you could just install the cable. What's it off of?
Yeah, I can post it but like Oldschool said, check to see if it unscrews first, that would be a lot easier. If not, let us know and Ill go snap a pix
..his Z..
Yeah, ity is for one of my Tri-Z's
I tried to unscrew it. Now I have to repiar the coil itself. I think splicing may be my only option.
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
I've got a spare in my hands here from a Z it does come out but they gule their's in, there's not screw. I was able to get the wire out of mine. It's in there about an inch. If you can get your's out you could easily glue a new one right in there. You mention you broke yours? It you broke the thin little plastic by the coil don't worry, it's not really doing much. It won't matter if you have it or not.
Duct tape. It works wonders. My friend did this with his beater suzuki 125![]()
[20:55] <waterpumper> putting a racing pipe on a Foreman is like putting a high dollar bikini on a 400 pound chick...just because it fits doesn't mean it looks cool
Once I broke the plastic I stopped messing with it. I may try what you suggested. Now the question is, Where do I get a whole new wire and cap?
85 Tri-Z's
85 Quad-Z,
85 YT175 For sale,
83 YTM 225DX,
85 YT 125,
89 Pro Hauler 230,
05 YFZ 450,
99 V-Star,
I have a better Idea. Take a die grinder/dremel with a cut off wheel and cut the plastic off the coil where the wire goes in. If your good you can get it off in one peice. After the wire is exposed cut it so you have a bout and in to work with. Use copper core wire since it flexes more readily. Solder a piece on a little longer than you need. Then take some silicone(not necesarily gasket maker, window sillicone will do) and fill in around the wire completely covering it, if you were able to get the cover off whole then put a little sillicone on it and stick it back on let it dry and you have a coil that will last . Avoid soldering copper and steel wires together because the mixture of the metal makes them corrode faster.
1980 trimoto 125 mods include a ripped seat broke fender and bent handle bars
1981 trimoto 125
1971 suzuki ts 185 it will spank a 200x
1966 gmc 3/4 ton
