Results 1 to 7 of 7
Thread: 300ex carb on a 250sx
    May 2002
    Southeastern Wisconsin
    3,658
    The topic came up when I suggested looking into doing this in another thread. The carbs look pretty close and I'm wondering how hard this may be. More importanly, will it help?
    Q#1
    What size is the 250sx carb?
    Q#2
    What size is the 300ex carb?
    Q#3
    Will a trike like the SX benifit from an accelerator pump?
    There's more Q's then that but it's a start. I'm checking but I think the 300ex carb is a 32mm.
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    31 mm 350x accourding to this site., but the carb fits in the stock boot, so the bell at the fron't may be the only thing larger.
    300ex Carburetion 32mm piston-valve with accelerator pump
    250es has a 22mm carb and I remeber reading that 22 or 28mm was used for the big red but could not find anything to substantiate it. Hopefully some one with a service manual can tell us something here.
    the question is weither or not the slide is bigger on the 350x or not. some of the larger keighn and mikuni carbs have the same body and slide and have larger bells or air horns.
    350x on 250sx
    http://3wheelerworldforums.com/showthread.php?t=20416
    http://3wheelerworldforums.com/showthread.php?t=2792
    http://www.3wheelerworldforums.com/s...ight=250x+carb
    http://www.3wheelerworldforums.com/s...ighlight=300ex
    theres some info in the above links.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    springville, PA
    6,185
    the sx is 27 so the big red should be about the same size.
    Awesome according to some of the guys I can just take my SX jets and put them in the 350x carb
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Aug 2004
    tallahassee FL
    392
    ok so 350x slide is 4 mm larger, but the external carb dimensions are pretty similiar, suposedly the 300es accelerator pump makes cold starting easier. Thats not as huge a problem down here in the south.
    May 2002
    3,658
    Ok cool, I see some searching could have yielded some good info but this is good. I'm shocked that the 350x carb is smaller then the 250x/300ex carb. If I had a 350x I'd be tossing the 31mm and installing the 32mm with the accelerator pump. The accelerator pump can help on start up but it's mainly there to help out when you pin the throttle, it gives it a little more go. As for the SX 27mm to 31mm is a heathly jump but not near as much as I thought. IDK why, but I thought the 350x had a 34mm.
    Aug 2004
    tallahassee FL
    392
    whats weird is how many times I searched this website for the info I just posted. I start searching the same things on google and I get 3wheelerworld.com posts Ive never seen before.....Gottas love google.
    Im still thinking 300ex carb not becuase its bigger but they are cheaper and more plentiful, Id hate to rig something up on my red resto mod that someone else coyuld use for a 100% OEM resto. ya know?
    May 2002
    3,658
    Quote Originally Posted by conig
    Great point!!! I'd think that accel pump would be nice too.
