Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 31
Thread: ordered a carb rebuild kit for the 250r* updated* check out what happened
    arizona
    550
    i ordered one of those rebuild kits today, should be here in 3 days, but i was just wondering how hard is it to do? ive taken apart carbs before, but its been a while. is there any pj carb diagrams around? i could really use one. the kit comes with the stock jet, but i have a clamp on filter on the carb, and a slip on. should i rejet?
    Pa.'s Highest City
    8,058
    My rebuild kit came with NO instructions. The manual is absolutly no help <well for me anyway. lol
    Do what I didn't do... If you got a digital camera take pics of it step by step. Remember how many turns to get the air/fuel screw out same for the idle screw.
    Was the air filter on there before? Any changes or mods may require rejetting.
    LOL... I've become somewhat of an expert on carbs over the last couple days.
    I had alot of problems with the air/fuel little rubber oring. The one in the moose kit I got was much bigger than the stock one. I couldn't get it to screw back in.
    Pa.'s Highest City
    8,058
    i meant to say air/fuel mixture thing look at the pics I guess all carbs are basically the same.
    The middle pic is where I ran into a problem. There is a little flat metal washer and an oring. that goes on there last.
    arizona
    550
    how do you adjust the needle setting? ive forgotten how to set it to diff clicks
    Pa.'s Highest City
    8,058
    If your talking about this then the 3rd notch (middle) is a good starting point. top clip is lean bottom clip is rich
    Richland WA
    808
    Its easy, just avoid overtightening the jets, they break easily. Clean out all the air passages with carburetor cleaner and compressed air if its available. Those little basketball inflation needles work great.
    arizona
    550
    i picked up the kit today, but i dont know exactly where everything goes, does anyone have a schematic or a diagram of what goes where? any tips? ill rebuild it tomorrow and let you guys know how it goes. all help appreciated
    Feb 2003
    California
    623
    Looks can be decieving. It was easy to me when I did it on my x.
    Pa.'s Highest City
    8,058
    http://www.3wheelerworldforums.com/s...ad.php?t=39134
    Check out the last couple pages of this thread... It may help.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    A torch tip cleaner works great also for cleaning jets and small passages in the carb.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Richland WA
    808
    Heres an exploded drawing from Keihin:
    http://www.keihin-us.com/pj.htm
    arizona
    550
    thanks tg6!
    arizona
    550
    good news! i just rebuilt my first carb, i think. the weirdest thing happened though. when i finally got the bowl off, i pulled the jets. the main jet is a 148 and the slow jet is a 42?!!?!!?!?! is this a 85-86 carb? because my kit came with the stock 130 main, which isnt even close to 148. nothing fit, except some springs and seals. what carb is this?
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    Post a pic of the carb.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    arizona
    550
    heres a pic of the carb attached
