Thread: choke frozen inside carb
    Sox is offline First Time Rider Arm chair racerNew to the board
    Aug 2005
    lockport ny
    94
    havent taken the carb apart yet... any ez way to fix this? would a new carb be easier? ive been starting it without the choke or elctric start. now it isnt that bad now... but im a small kid kid and in winter this will be a big pain.
    oddball3's Avatar
    oddball3 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Apr 2004
    New Jersey
    224
    Your bike has the choke slider on the left side handle bar? Could be the cable stuck.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1985 200x fixer upper
    1979 110 PARTING OUT
    1984 70
    http://www.hardcoresledder.com/forum...post&id=155447
    '97 ZRT 600 drag sled
    '97 ZRT 600 trail sled
    '98 ZR 440 sno-pro(wifes)
    http://www.hardcoresledder.com/forum...=post&id=79401
    Aug 2005
    lockport ny
    94
    nope took the carb off the engine wen i was fixing it up. the choke is frozen inside the carb, it wouldnt move wen i tried by hand with the carb off. the slider thing is broken too. but i think the cable is ok. i also need to adjust this carb its kinda grumpy. like wen * first start it it idles real high. this often results in wheelies wen shifting into first.
    oddball3's Avatar
    Apr 2004
    New Jersey
    224
    Soak the choke shaft in penetrating fluid for a while before you force it.
    IN MY GARAGE:
    1984 250r
    1986 350x
    1986 200x(wifes)
    1984 70
    Aug 2005
    lockport ny
    94
    ok ill try that ** i take the whole thing apart.
