Thread: 2 Questions about the YT175
    angryyoung is offline At The Back Of The Pack Arm chair racerFirst time rider
    Ontario, Canada
    164
    1) Are they supposed to have a chain tensioner?
    and 2) can anyone give me a wiring diagram for this bike?
    Thanks alot
    -Rob
    Ontario, Canada
    164
    or at least a wiring diagram for the rear brake light??? Cause i dont know how the brakes engage the brake light.
    Mar 2005
    Alberta
    503
    Yes, there is a chain tensioner. On mine, you have to loosen the rear axle carrier bolts, then tighten an external tensioner. I have an old parts wagon that is either a 125 or 175. It has a tensioner inside the chain case, it's another sprocket that is either spring loaded or you have to manually adjust it. Not sure which because I've never messed with it.
    As for the brakes engaging a "brake" light, I don't think they had them, just a taillight.
    A whole bunch of trikes.
    Ontario, Canada
    164
    anyone got pics of the tensioner?
    Mar 2005
    Alberta
    503
    Here's the pics. I stand corrected about the axle carrier bolts, you don't have to loosen them, just the ones on the tensioner.
    Attached Thumbnails Attached Thumbnails DSCF0468.JPG   DSCF0469.JPG   DSCF0470.JPG   DSCF0471.JPG
    Ontario, Canada
    164
    Thanks freewheel3, you been a big help!
