Results 1 to 9 of 9
Thread: how do i put new shock boots on a honda B.R.250es
    svo58 is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2004
    clifton park,saratoga county,N.Y.
    166
    Has anybody done this before.I want to know, do i take out the allen head screw on the bottom of the shock to get the lower fork off.I read the book it's not to clear to me.I think you have to get the lower fork off to put new shock boots on.Does anyone know if this is the rite way to get it off,the allen head screw on the bottom and it slids off?Any help would be great,thanks......svo58
    84 big red 200es with speedo
    84 70cc ATC- new top end ,rear rack, head light and tail light
    85 250es big red
    85 250sx
    Jul 2004
    Baton Rouge, LA
    946
    All you should have to do to put new shock boots on is to take the forks off of the tripple tree and just take the old shock boots off and put the new ones on. You're talking about the black rubber shock boots right?
    1985 Yamaha 225DRN w/OEM headlight guard, footboards, front rack, rear rack, work light, brush guards and trailer hitch
    Jul 2004
    166
    I can't get the forks off at the top,i've tried everything.is there another way.How do you take the bottom part of the fork off?????
    85 250es big red
    85 250sx
    Jul 2004
    Baton Rouge, LA
    946
    Oh ok I see. What you should do if the forks aren't coming out of the tripple tree is to make sure you take all the bolts out of where the forks are held in the tripple tree, then spray some wd40 all in that area and then use a shop rag to grip the fork shaft and turn it back and forth til it loosens up. You really don't wanna disasemble the forks if you don't have to....
    Jul 2004
    166
    Could i use a pipe wrench to brake it free.The darn thing won't move or twist,all the bolts are out and its been soaked for days.Any tips on getting it off
    85 250es big red
    85 250sx
    Mar 2005
    Alberta
    503
    If it's similar to the 185 & 200s forks, sometimes I drive a chisel in between the fork clamps to spread them a bit. The fork will usually come out then. Just don't drive it in any further than necessary otherwise you risk breaking the clamping portion of the forks.
    A whole bunch of trikes.
    May 2005
    Fort Worth,Texas (watauga)
    112
    ^listen to what freewheel says....it`s the way to do it....done it myself many times over the years.....you DO NOT want to take the bottom end of the fork off unless you are rebuilding them or replacing seals or something along those lines.....and DEFINITELY DO NOT use a pipe wrench on the fork tube...you will damage the tube and the burrs it causes will shred your fork seals!
    trikes owned:
    1982 ATC 185S
    1983 ATC 185S
    (2) 1984 ATC 185S
    1984 ATC 200M
    (2) 1984 ATC 200S
    (3) 1984 ATC 200X
    made one an auto-x,easy swap
    1985 ATC 250R (stolen!...the bastards!...it was mint!)
    own now:
    1985 ATC 250R (running)
    1986 ATC 250R(parts bike)
    1984 ATC 250r w/ 280cc kit in it(pretty rough-needs TLC)
    1984 ATC 200s (running)
    1982 ATC 185s (running)
    (2)1984 ATC 200s(parts)
    1984 ATC 70 (parts)
    1983 ATC 70(off ebay-running)
    1985 ATC 70 (running)
    198? ATC 70 (running)
    1984 ATC 200x (running)(have made it an auto-x until i rebuild the top end of the X motor)
    1985 ATC 200x roller(gonna make another auto-x)
    Eric
    Jul 2004
    Baton Rouge, LA
    946
    OH yeah, I remember sticking a large flat head screwdriver in there to spread it apart a little and the forks came right out.
    Apr 2002
    s.w. michigan
    6,498
    yep,,,
    Yep,,, getting those fork legs to drop out is really hard since they probbly have not been out of there since put in from the factory. But that is the proper way to put the boots on.
    Also ,,, it is the only way to change the fork oil too. So plan on a fork oil change when you get the fork legs dropped out.
    john
