Could any one please help out I bent my axle on my 350x today I need to know if any other axle will fit please. .(Shame job bent it trying to do same jump as my wife on her new 400 ex.)
The 250r and 200x axle look about the same to me. I'm not 100% sure though. I just pulled a axle of a parts 200x. Do you want a pic to compare?![]()
Yes if you could please that would be great thank you .
I'm pretty sure the 300ex axle is the same.
'02 ranxher 4x4 '83 big red '84 110, '86trx70 project, '85 bigred project
It's about 33 1/2 inches long and 1 3/8 wide in the center between the rotor and sprocket. Here the pic. I hope this helps.![]()
I was just looking at bikebandit.com to compare and the sprocket mount is different. If the splines are the same and the length is too then it should work. Also the 250r axle is part number 145642-001 and the 350x is part number 145644-001 and the look about the same. It just the length and spline size you need to worry about. Good luck![]()
Thanks brendan 802 Iwas just loging on to that site . I think i will go with a aftermarket axle there seems a lot on ebay.I just have to make sure that the on i get is right for my x. Freight alone is $130.oo aud.cheers.
No luck finding same part no for 350x axle on bike bandit What aftermarket axle would be the best to buy.Please.
Now i realy do need a axle our local shop here said that they could fix it they heated it up cheery red and tried to straighten .The bend is worse ,Throw away job.I am thinking of selling and buying a Quad .At least parts are not a prob.
The axle on an 85 350X is specific to an 85 350X only.
I've been down this road before.![]()
SloPoke
85' ATC350x
8? ATC70
Bend it back to shape, the only bad thing is that it will be weaker. Buy a durabluel. Or trade er for an ATC250R, least * will be able to keep up with ** wife.
Rest in peace Rex Carlson
The 350x can use a 300ex axle. Other than that you need a 350x axle.
Thank you for the help guys I got a new old stock axle for my x today from the USA (me very happy chappy.) Wife not happy though I pulled her axle last night to try on my x did not fit . ( mmmm must remember to put it back on her quad one day. :l: Thanks again all.
