Results 1 to 15 of 20
Thread: Cam removal 1985 200x help
    Solid Snake is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2005
    Lancaster, PA
    316
    Can I remove the cam with the engine still on the trike? Someone told me that if I remove the cam sprocket and hold the cam chain I can pull the cam out without taking off the cylinder head cover. Is this true? When I place it back in should the lobes be facing down and then line up the sprocket and stator mark? Any help would be much appreciated. Thanks.
    Aug 2005
    HI
    1,575
    Why don't you try it and then tell us the result.
    Rest in peace Rex Carlson
    Aug 2005
    Lancaster, PA
    316
    I've never done it before so I'm kinda worried about messing something up. The guy that told me about that is not around here anymore so I can't ask for his help if I need it.
    Aug 2005
    HI
    1,575
    Why do you need to do it anyway?
    Apr 2002
    s.w. michigan
    6,498
    yep.
    Yes you can remove the headcap ( very top of the motor that has the vales in it ) and remove the sprocket then the cam.
    A couple of tips ( buy a manual is the at the ver top of the list ).
    1 - set the motor (piston) at "top dead center" on the compression stroke.
    2- loosen the headcap bolts evenly starting from he center and working outwards in 2 or 3 steps.
    3- stuff rags on both sides of the cam chain gear so as to not drop either one of those cam chain bolts down into the case ( it's really hard to shake them out with the motor upside down in your arms - or worse yet ,,,, tear the whole stinking motor aprt to retreive them )
    4- tie a strong string around the cam chain when you get enough slack in it so it don't flop down in the bowels of the motor.
    At that point you should be able to wiggle the cam out of there.
    Reasembly ,,, reverse the above. seal the head cap mating sufaces with a sealent made for such purposes. you really should have a clymers. honda or suitable manual for going inside the motor cuz there is sevral little things to be aware of when doing so.
    john
    Jul 2004
    Mud hill. close to water !
    3,658
    Once you remove the timing advance / rotor thing....
    REMOVE THE LOCATING DOWEL FROM THE CAM AND PUT IT ASIDE !!!!! Unless it's stuck in there VERY well..... Do not let that thing fall into the bottom of the engine.
    Currently :
    Apr 2002
    s.w. michigan
    6,498
    yep
    oh yeah ,,, for about that "little " detail bigredhead.
    john
    Aug 2005
    Lancaster, PA
    316
    I need to pull it out because my timing is off, I had some guys work on the engine and they set the timing 180 degrees off. Thanks guys.
    Aug 2005
    HI
    1,575
    You put the O, on top. Oh if i am wrong i am about to screw myself over. Am i right?
    Mar 2005
    West Virginia
    96
    Quote Originally Posted by Solid Snake
    There is no such this as 180 degree off in a single cylinder!
    they may have gotten it a tooth or two off but you can never get it 180 off, cause that would be where you want it, on either side of 360.
    remember that your single cylinder 4 cycle fires on every upstroke (well a few degrees before TDC) it fires once on TDC compression resulting in combustion, it also fires once on TDC overlap resulting in wasted spark.
    Aug 2005
    Lancaster, PA
    316
    I see, but anyways it is definately off a tooth or two because when I look through the timing "T" mark on the stator on the compression stroke the cam sprocket is definately pointing towards the ground but not completely towards the ground. I would say it's 2 teeth off, and that's why my trike is running like crap and is mad crazy hard to start. To fix this they moved the pulse rotor base around a few millimeters from the notches until they thought it was ok. I noticed that right away when I took the c.d.i. cover off.
    Oh yeh I do have a Clymers now, and someone sent me a Honda shop manual, so it looks like I'm good to go.
    Jul 2004
    3,658
    You don't need to remove the head or cam to adjust the timing or to skip a tooth on the sproket....... just loosen the tensioner and the 2 screws that hold the top sproket on and pop it off the cam.. jump a tooth by working the links over one at a time and put it back together... Don't break that seal on the head cover if you don't have to.
    Also.. don't forget to gap your rotor to spec. If it was played with and not adjusted with feeler gauges.. i bet it's off..
    Currently :
    Aug 2005
    Lancaster, PA
    316
    Thanks for the tip bigredhead. I got a question though, the tensioner bolt...I know where that is under the rubber cap but is the one that I should loosen the 6mm Bolt that threads into the larger bottom one or the bottom one? Do I just loosen it and that's it? And when I go to tighten it apparently this is suppose to work itself with the engine running...the tensioner bolt I mean? Thanks.
    Jul 2004
    3,658
    ok.. the 8mm bolt.. leave it be.. don't bother with it.
    Turn the 14mm bolt clockwise to loosen the chain.. and counter clock wise to tighten it.. it's oposite of what you would usualy think... the tensioner is spring loaded and counter clock wise alows the spring to push on the tensioner and tighten your chain.
    Currently :
    Jul 2004
    3,658
    oh.. about the 8mm bolt.. all it does it give you access to the tensioner when assembling the engine. You can remove it if you want.. nothing bad will happen.
    Currently :
