Check the routing of your throttle cable too! My 82R cable would stick and I replaced it with a MotionPro cable (about $12). It was fine until I switched gastanks (IMS plastic back to stock metal) When I did, it would "stick" if I made sharp right turns. I checked the cable routing and I found that I had it in the wrong loop behind the headlight. As I turned L-R-L-R, etc, it would creap up the loop until the cable pulled on the carb.... it's all good now.
If worse comes to worse, I live in Western NY.... I can come check it out or something....
Bruce
'86 ATC350X - 'Go-Go Girl'
'85 ATC70 - All Original
'83 Suzuki ALT125 - Pieces
