Here's the specs for a YTZ250N from the book, maybe it'll help.
Carb Type: Mikuni VM32SS
ID Mark: 38W00
Main Jet: 470
Air Jet: 2.5
Jet needle/clip position: 6H3/3
Needle jet: P2
Cutaway: 2.0
Pilot jet: 45
Pilot air screw: 1 turn out
Valve seat size: 3.3
Starter jet: 1.3
Float height 31.3 +/- 1.0MM (1.23 +/- 0.04 in)
And here's what the book says about Idle speed and mixture.
1:the idle speed should be checked and adjusted when it is obviously too high or low. before adjusting idle speed, make sure ignition timing is correct and spark plug is properly gapped.
2:the engine should be at normal operating temperature and in neutral.
3:attach a tachometer to the engine.
4:turn the throttle stop screw to obtain specified idle speed.
5:if the engine misses or runs erratically, turn the pilot air screw in until it seats lightly, then back it out the specified numbers of turns.
6: reset the idle speed with the throttle stop screw.
7: turn the air screw in or out, as required, until the highest engine speed is obtained, then reset the idle speed with the throttle stop screw.
hope this helps.
Trikes:
1973 Honda ATC70-orange!
(2)1985 ATC70
1985 Big Red 250
1985 250R
