Page 3 of 3 FirstFirst 1 2 3
Results 31 to 38 of 38
Thread: A couple golfcart questions (grizzly 600)
  1. #31
    Mar 2005
    overton, PA
    5,257
    i owned this quad at one time the entire electrical stystem has been replaced , then the carb builds up so much heat under the tanka nd it vaporizes the fuel in the fuellike and the floatbowl and doesnt run verry well but if you run it wot constantly and move enough fuel trough it it runs fine. belive me thats why my girl friend coudl never rid eit but the transmission was totaly trashed. blew it into a million pieces. so dont jump it it will blow it apart.
  2. #32
    Mar 2005
    overton, PA
    5,257
    i am tellign you it just builkds up alot of heat. i rod eit for hours in the snow and thjen it woudl die and not want to restart until it cooled off alot
  3. #33
    Pa.'s Highest City
    8,058
    Would can I remedy this mototor getting to hot. Drill mores holes in the plastics?
  4. #34
    Mar 2005
    overton, PA
    5,257
    try rynnign it without the plastic shrouds arounjd the motor or front plastics i am certin it runs alot better. try it and belive me .i actualy wanted to build vents to let alot more air flow trough it but it wouldnt have helped from what i use dto do with it. 95% of the riding i did was deep mud.
  5. #35
    Mar 2005
    ma
    988
    was there ever a recall on the grizzly for that kind of problem?
    does it have a fan? its aircooled right?
    Billet Triz 250 parts, Case Savers, Engine Mounts, Boost Bottles, Oil Caps, and Shifters, pm me for info
    Shock Rebuilding, PM me for details TRI-Z Shocks rebuilt too
    My Feedback
    http://www.3wheelerworld.com/showthr...k-for-sblt500r
  6. #36
    Front royal, va
    2,186
    hey, i found my old grizz, that was mine awhile back!then josh, then a guy in jersey, now you!
  7. #37
    na
    5,702
    my brother in law had one of these 600 grizzes. he had loads of problems with it.take the side plastic covers off.they just run too hot.another thing to check is,the tubes coming off the bottom of the carbs.they get clogged with mudd and wont let the float bowl fill back up.the tubes run down between the frame and swing arm.take them off and blow thru them. make sure they are clear.he also had a problem with the wiring harness,but you said your is new.some coneections melted under the front plastic by the steering stem.also,your valves,if adjusted too tight,as the motor gets hot,the stem of the valve expands.this will in turn push the valves some what off the seats,cuasing a loss of seal at the valve seats until they cool back down.if the motor ticks alot,then it is possible that the timing chain is worn and someone adjusted the valves too tight trying to get rid of the ticking noise.hope this stuff helps.i would check those tubes on the bottom of the carb first.very common problem.
    Proudly NOT a member of
    "Team on the Teat"
  8. #38
    Pa.'s Highest City
    8,058
    Quote Originally Posted by 03 ORANGE SHEE
    WANT IT BACK???
    So which one of you guys beat this thing into submission?
    Moshman... Thanks for the advice. At the moment the quad is buried in the garage again as i recently moved and haven't had a chanche to work on it. But I will look into these things that you mentioned.
