I installed a new rod, ball, ajuster, fibres, metal plates, and spring in my clutch and it now works perfect. But now I have a few other problems.
There are a few carb problems that I could use some help figuring out.
1) When you rev it up, dump the clutch, it slows the engine right down and you cant take off fast. Its got absolutly no low end power.
2) Mid range is alright, but when you get to WOT, it breaks up.
3) First, second and third gear will not wind right out, its not until you get to 4th it will wind right out.
4) Very low idle (I'm just going to try and ajust the idle screw)
It had a 490 main in it earlier today and that was even worse, I fouled my plug, so I went down to the only other jet I have right now which is a 480. I'm going to order some more main ones, any suggestions on which sizes?
Everything is stock except for a Cobra exhaust with blown baffles (I need a new pipe)
I am going to try the Blue Marbel oil I have next fill up, and I hear its supposed to richen it up.
If someone could help me out with this, It would be great
