Results 1 to 15 of 18
Thread: anyone else stand there trike straight up to drain their oil?
    Dec 2002
    salem, nh
    1,339
    if i dont stand my 200x straight up in the air it only drains about half of the engine oil. WTF is up with that? Also, how come once you change gears after the oil bolt is out, it has to be in neutral to screw back in?
    85 250SX New to me!!
    85 ATC 70 stock ~ TRADED
    85 ATC 70 with 138cc Lifan
    83 110 restored ~ sold
    85 110 restored ~ sold
    83 200x restored ~ sold
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    Removed choke 42 pilot DJ146 main
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    IMS Roll front bumper
    Graydon Proline nerfs
    Apr 2003
    Central New York
    1,860
    weird
    That is weird and beyond my compehension as to why you need to do that. How does she run?
    84-85 Custom Tecate
    1986 Honda 200X Daily Rider
    2006 Suzuki King Quad
    Apr 2003
    Central New York
    1,860
    That is weird and beyond my compehension as to why you need to do that. How does she run? Is there any problems with the motor or did you have an ATV doctor work on it and leave his wrench in the motor
    84-85 Custom Tecate
    Jan 2005
    RI
    2,530
    ever hear of an oil drain plug?
    Jul 2004
    Mud hill. close to water !
    3,658
    I do that to change the rear diff oil on my SX.. open the fill cap, put tray under diff.. pick up the front forks and ballance the trike on it's rear wheels. let oil drain, drop forks re-fill put cap back on. 5 minute job.
    removing diff cover.. removing drain screw with 10mm bolt.. wait...... 20 minutes.
    As far as oil when you tip the trike ... front wheel up .. or on it's side ? I've always kicked the motor over a few times to get the pump going and spit out the oil in the lines running to the head.. at least that's what i think goes on.. but i do know that you get more oil after a few revolutions of the motor. even after it's totally drained.
    phew.. this was going to be a 1 line reply too....
    Currently :
    Jun 2004
    Brazil, Indiana
    1,389
    i turn mine on the side...
    trikes owned:
    85' 200m - sold
    84' 200x - sold
    83' 185s - sold
    82' 185s - sold
    85' 350x !!! - selling
    Aug 2002
    NY
    2,652
    like this?
    Newfoundland
    5,280
    So you tip it back on the grab bar to drain the oil? WHY?
    springville, PA
    6,185
    Quote Originally Posted by 83185s
    Its not supposed to come out that hole, just go in
    Nate
    The Myth, The MAN, The Legend
    R.I.P HRR
    Jan 2005
    Spruce Head Island, Maine
    893
    lol i think hes right try the bolt on the left side of the motor, might work better
    1983 Honda ATC 200x-shes a beater
    Past Rides:
    1982 ATC Big Red 200e (miss it more than i thought i would)
    1985 200x rode it for about a mile
    Glenn J's Avatar
    Glenn J is offline At The Back Of The Pack Arm chair racerFirst time rider
    Jul 2003
    Wallyword, CT
    155
    It sounds like he's draining it from the bolt on the very back of the engine...hence why the machine needs to be in neutral to get the bolt back in.
    1985 200X
    conig is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Aug 2004
    tallahassee FL
    392
    Mike from Long Island is that how you store yours or how you drain the oil, I plan on storing mine like that when I get my new shed/work area.
    1983 honda 70atc, als,ot done, need throttle cable and assembly. PM me if you have this.
    1985 honda es 250 big red.
    85 percent restore. 10x10 douglas 190's 22-11-10 at 489's. 12x7 itp c series 24-8-12 swamp fox. some accent painting. snorkel everything and a custom PCV system. moose air filter. cobra utility exhaust. 2.5 um wheel spacers.
    A trike to show up the modern utilitys
    2002 scrambler 400 2x4 uni pod filter, lots of weight shaving, v force reeds, HPD race pipe, 39mm pwk or 34mm, 12-1 head, trail porting, custom clutching, hole shots on t-9s +1 all around. works shocks . trail bike with drag tweeks.
    Dec 2002
    salem, nh
    1,339
    Quote Originally Posted by Glenn J
    i am, isn't that where i'm supposed to drain it from? i know about the large nut on the side that has the screen filter in it and i clean that out also.
    02 400ex ~~~SOLD
    K&N filter
    K&N jet kit
    EHS Racing lid
    HMF full exhaust
    AC skids
    Holeshot XCR rears
    14t front sprocket
    Anaheim, CA
    517
    no you drain from the side bolt. i beleive what you are draining is the trans oil. i personaly drain both
    Jan 2005
    RI
    2,530
    yeah that big bolt type deal with the screen and the filter is where youre supposed to drain it from
