Results 1 to 9 of 9
Thread: 250R wont pull 6th!
    Jun 2004
    Oregon
    1,782
    250R wont pull 6th!
    Went down to the dunes today! Bike ran awesome for the most part.Pulls hard though all the gears till i get to 6th..In 6th it just bogs down! Now is this something i have to deal with or could it be a gearing problem or a jet problem? Did 3 plug chops and they all came out kinda dark, but not to bad..My gearing is stock 13/39.Could i bump up my rear to a 41 or jet down another size? Or is this just something i have to live with.......Thanks!
    1986 ATC 250R
    Ported w/ Cool head
    LED pipe and silencer.
    Vforce3
    Keihin PWK 38mm
    Works Ultra Cross Shock
    LSR +2 Axle
    American Star Racing +4 Swinger
    LED Intake
    Hi-Flite desert seat
    OEM clutch 89 upgrade
    2021 YFZ450Rse Rossier R5 Titanium Header AIS Delete FCI Vortex ECU
    Mar 2004
    Eastvale, CA
    630
    Fox, when you say your R won't pull 6th, where exactly are you riding, on the flat, cruising the dunes, or shooting comp hill? It should easily pull 6th on the flat, but probably not on the hill. But, if you're running too much tire for your motor, that could be some or all of the problem.
    Current Ride (Purchased new in Oct. 84) - 1985 Honda ATC 250R w/ ESR 310cc big bore kit
    Wife's Ride - 2009 Polaris RZR 800
    Kid's Rides - 2009 Yamaha Raptor 700, 2008 Yamaha Raptor 250
    Former Rides - 1975 Honda XR 75, 1979 Yamaha IT 175, 1978 Honda ATC 90, 1980 Honda ATC 110
    got sand?
    Jun 2004
    Oregon
    1,782
    On the beach flat out! Pulls 5th no prob, but when i hit 6th it bogs down....Im about 195 so i dont think weight should be a problem..
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Phoenix, AZ.
    6,719
    How does it do shooting hills? Any bogging in lower gears?
    Jun 2004
    Oregon
    1,782
    4th no prob maybe 5th if i really reved it out....
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Washingtons Crossing, Pa.
    2,977
    Based off of the plug readings and the long gear die off - It does sound like you are too high on your main - just a little. I would drop down one size. Are you running an open air-box?. If you arn't, you might try taking a run with the lid off before rejetting to see if that clears it up. If it does - you are too high on the main. It could be fuel delivery related too - but - I'm leaning twords Jetting. Always check your cap breather tube too - that simple sucker has caused so many people headaches on here in the past.
    Jun 2004
    Oregon
    1,782
    i dont have an airbox and im running a 172 but i just dropped to a 170 and im going to the dunes this weekend to try her out And my cap breather is perfect...
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
    Feb 2005
    Oregon
    772
    Quote Originally Posted by Fox250R
    What type and size paddles are you runnin. Try really revin'n it out in 5th and shift it quickly into 6th and see if you cant pull it. I know blazers 250r had no probelm pullin 6th and it had a pipe and lighten'd flywheel, If I rember right you have done a lot more to yours.
    1986 310R
    1975 F150 4x4
    1975 F250 4x4
    1968 F100 2wd
    2001 Dodge 1500 4x4
    Jun 2004
    Oregon
    1,782
    skattrack haulers 20x10x10.......
    1986 ATC 250R
    Ported w/ Cool head
    Vforce3
    Keihin PWK 38mm
    LSR +2 Axle
    LED Intake
