Results 1 to 15 of 16
Thread: Short Track Repro Shroud Pics
    May 2005
    Australia
    1,047
    Thumbs up Short Track Repro Shroud Pics
    Well i had a sickie from work today and started on the 85/86 Short Track shroud molds.Ive just flipped the mold from the right original part(no damage done to original) and here it is ready for trimming and filling of the imperfections as you can see,will have the left one at this stage tomorrow.For those TRI-Z guys i actually spent half the day on those molds as well making a template for use of a router to remove the waste vent plastic so in all a very productive day here "Downunder"
    Cheers
    Aussieduner
    Attached Thumbnails Attached Thumbnails ST Shroud Mold & OEM.jpg   ST Shroud Mold.jpg
    Keeping 3 Wheelers Alive Downunder !
    Mar 2004
    North Central Ohio!!
    2,712
    So, now on these parts, what colors are you making them in? Are you going to try to make them in OEM colors? I know everyone is anticipating the vented number plates, I know I sure want a couple red ones. You may think of making the numbers to go with them as well, to sell seperate.
    Another rare item to reproduce might be the 1985 CR500 shrouds. I know those can't be bought anywhere.
    May 2005
    Australia
    1,047
    Quote Originally Posted by Derrick Adams
    Hi
    Well ok heres the deal so far any of the molds i have i can make the item in black or white in 3mm,im waiting on polypropolene material that will come in yellow,red ect but the material is hard to obtain BUT i have an order in with a big plastic's company for those colours.I have a vented plate coming and it should be very easy and quick to produce also im picking up a router to speed up production time and working on templates to make each item trimmed the same.
    As for numbers for the plates this will be very easy my plastic supplier has a "MultiCam" machine that cuts plastic letters or numbers(or shapes) in any size or font required,its all linked to a PC with AUTOCAD.
    Aussieduner
    Bartlett TN
    3,083
    Nice job there mate! I am sure I will be put in line for a set of them! It just goes to show that anything can be done if someone works at it! Great job!
    86-87 Tecate ROCK!
    May 2005
    Australia
    1,047
    Quote Originally Posted by ScottZJ
    Hey thanks.
    Thats a nice ST 250r you have there yourself,im taking my frame for powdercoating this week and a rebuild with new fenders,fork boots,decals etc and of course the ST kit fitted.
    Aussie
    Bartlett TN
    3,083
    Well it will be nicer once I get a nice set of shrouds for her....hehehe
    86-87 Tecate ROCK!
    May 2005
    Australia
    1,047
    No problem will be able to help with that very soon :-)
    Aussie
    May 2005
    Australia
    1,047
    Updated Mold Pics
    Molds are now a solid item,a little more work around the outside to seal the expander foam and they are ready to start production !
    Cheers
    Aussie
    May 2005
    Australia
    1,047
    Thumbs up First ST Shroud Done,take a LOOK.
    First ST shroud straight off the vac table today,what do you think ?
    Cheers
    Aussie
    Attached Thumbnails Attached Thumbnails ST Repro Shroud 1.jpg   ST Repro Shroud 2 (1).jpg   ST fitted 2.jpg   ST Fitted.jpg
    Jun 2004
    Pyeongtaek, South Korea
    474
    Lookin' good, Aussie! Have you heard from your plastic supplier about the other colors yet?
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    May 2005
    Australia
    1,047
    Quote Originally Posted by 69HemiGTX
    I have no good news on yellow 3mm poly yet,i have one last hope next week with that,2mm is readily available as its used in saftey signs etc but just too thin for this application.Its crazy the amount of yellow plastic items i have found here at home and in stores like plastic cups,dog bowls,garbage bins and so on but they are all made in China,Thailand and elsewhere,There has to be somewhere here in Oz that has this material in sheets,very frustrating.
    Aussie
    Phoenix, AZ.
    6,719
    I wonder if there's a way to find out who supplies Maier with their plastic. That way you could color match them perfectly.
    Billy Golightly's Avatar
    Live Oak, FL
    15,070
    I'm pretty ignorant on the whole process of vacume molding plastic, so this is probably a stupid question, but how about just taking two 2mm sheets and stacking them up?
    Phoenix, AZ.
    6,719
    It doesn't get hot enough to melt them into one piece. It would end up coming apart.
    Live Oak, FL
    15,070
    Could the heat range be increased, for use with the thicker plastic?
