Results 1 to 2 of 2
Thread: 200x wont shift from 1st, plz help
    Southern MN
    1,875
    Its the 85'. I recently purchased a bottom end from a seller on ebay, the top end was froze. I rebuilt the top end and then got it running, and rode it for a little while, shifted through all gears fine. Then something happened to the transmission, and now it wont shift out of first. You cant even get it into neutral. I pulled the right side case and cant seem to figure out what the problem is. I was going to swap the shifter shaft setup with another complete one that I have from a different tranny, but I cant get that stupid bolt off the clutch. The bolt I am talking about is the one with four etches which you cannot possibly turn with a regular wrench. Has anyone on the board ever got that stupid thing off? How do you do it? If anyone has any clue as to why i cant shift out of first gear, please let me know. Thank you for your time and consideration.
    81, 85 Yamaha Tri Moto 125
    83 Yamaha Tri Moto 200 x2
    85 Yamaha Tri Z 250
    84 Kawasaki Tecate 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    (2) 84 Honda ATC 200x
    82, 83 Honda ATC 185s
    81 ATC 200
    Lots of other parts and bikes
    Southern MN
    1,875
    The 200x does not have the auto transmission, it is the stock one, clutch and kickstart, if that makes any difference.
    85 Yamaha Tri Z 250
    84 Honda ATC 70
    85 Honda ATC 350X
    84 Honda ATC 250R
    81 ATC 200
