Page 2 of 2 FirstFirst 1 2
Results 16 to 26 of 26
Thread: Dual oil coolers and whitebrothers eseries exhaust on my 350x
    PA
    3,515
    Quote Originally Posted by tanks350x View Post
    here's a question for ya.... Is the oil pump strong enough to pump all that oil?? I'm wondering if the extra cooler puts more of a strain on the pump, with the extra volume
    with a new pump its fine, one thats only working 50%....not so good
    WWW.HREATV.COM
    AJZ_200X's Avatar
    AJZ_200X is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2007
    GRAND RAPIDS MICHIGAN
    363
    Do you have a sound clip of that exhaust. Looks wicked (probably sounds wicked to)
    Oct 2007
    Grosse Tete, LA
    3,440
    Quote Originally Posted by willrideanythin View Post
    FST makes an aux oil cooler kit. I think its under 100
    who what when where how?
    I want one.
    Fresno Ca
    2,695
    Quote Originally Posted by 350xrider911 View Post
    do i see a 400ex carb on the white one.
    At that point in time it was acutaly a 05 trx450 carb. Then i went to the 400ex carb, Then to the FCR.
    I have never had any problems with oil or heating on that bike. Mainly jetting and octane rating is the biggest factor on operating temp You richen it up and it will cool your bike down if your having problems. I woudnt do the oilcooler unless your running frequently in +100 degree temps.
    Ill see what i can do to get a clip of that exhaust. I also did a new one that sounds even better, Its a DR D off of a trx450 Im going to do a writeup on how to do the exhaust and get it on 3wheeler.org/vb
    Oct 2007
    Grosse Tete, LA
    3,440
    down here during the summer it sits over 100 degrees...I figure every little bit helps.
    NOS...what was your jetting with that fcr...I know mine won't be the same, I'm just curious about a starting point for the leak jet and main.
    also...what in god's name does that "mikuni" style jet in there do...and di you change it?
    Nov 2004
    Waterloo IL
    2,701
    So what exactly had to be done to the head pipe? I still have brand new take off 400EX exhaust from a 400 I bought new in 2003 and I would like something other than DG on my 350X.
    08 Outlaw 525s
    07 CRF70
    04 Harley FLHRCI
    04 TRX90
    03 XR650R
    03 400EX- XR650R engine
    02 XR100R
    01 Banshee
    00 XR50R
    00 XR70R
    99 PW50
    99 JR50
    96,95 Sportsman 400
    95 Xplorer 400
    94 Indy XLT
    87 Trail Boss
    86,86,86,86,86 Scrambler
    86 TRX70 x2
    85 ATC350X
    85,84 ATC250R
    85 Red Tecate
    85 LT50 x2
    84 XR500R
    84,84,84,84,83,82,80,79 ATC70
    82,79 XL500R
    83 ALT50
    79,78,77,77,76 XT/TT500
    76,75,74 XL70
    72,71,71,71 SL70
    72 Harley FX
    72,71,70,70,70,70,70 CT70H
    72 SL100
    70,69 Z50
    Newfoundland
    5,280
    White Brothers E2 is the way I would go. Its a great woods pipe.
    PA
    3,515
    Quote Originally Posted by NOS_350X View Post
    a stock cooler is not big enough for a big bore stroker 460...its needed
    WWW.HREATV.COM
    Fresno Ca
    2,695
    Swigin, What tep do you run at that you must have a secondary oilcooler? now is this fact that you go big you must get one or is it just your oppinion?
    Goat, With the 400ex carb and 450 carb i was well into the 200's (around 220 on the ex carb) With the FCR carb i then was able to be around the 175 range.
    Im not shure exactly which jet your talking about (its been a while since i had to pull the bowl off) but its eather a Leak jet for the acclerator pump, or a starter jet. no need to change.
    Blown, 1 easy cut, Grind, Weld and your set, With the 400ex headpipe and a 450 stock or aftermarket pipe the rear mount even lines up, With the 400ex rear pipe you have to make a new location for the rear pipe mount.
    Isnt the Eseries pipe the one that was falling appart on everyone?? i think so.
    Oct 2007
    Grosse Tete, LA
    3,440
    with the 37 fcr...were you able to use the choke...or...did you simply jet it to where it would start?
    ...stock in the 37 I purchased was the 42...seems like a 45-48 would be more correct.
    But back to the thread, if you still have pics, would you post them up? I'd like to see this cooler mod.
    also, with your huge main jets, were you running something larger than an 83mm piston?
    PA
    3,515
    temps range from sub 0 to 100
    and im talking about larger then stock coolers not dual stock ones.
    i used to run a stock cooler on my 350x quads but a 450r cooler cools much better. and the 460cc motor my buddy built will over heat when it's 80 degrees and up with a stock cooler.
    WWW.HREATV.COM
