Results 1 to 11 of 11
Thread: 86 250R axle interchanging with TRX250R ones
    Billy Golightly's Avatar
    Live Oak, FL
    15,069
    I searched and found a person who said they were but I just want to confirm that is correct. I know the 85s wont, but I want to make sure the 86s do.
    Jun 2004
    Pyeongtaek, South Korea
    474
    To the best of my knowledge, the 86 ATC250R rear end will bolt right on to a TRX250R and vice versa.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    KASEY's Avatar
    ARIZONAS BIGGEST TROUBLEMAKER
    4,241
    now to throw a wrench into the spokes,,,,, i have a 88 trx axle in one of my 85 250r's,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,, ,,,,,,, no modifications either,,,,,,,,,
    Live Oak, FL
    15,069
    Different brake hub/bearings/carrier or a combination of it? I'd be interested in knowing how you did that.
    Dec 2003
    SE PA
    683
    I have a 400EX axle and carrier in mine, with the 250R brake hub. Haven't had any trouble with it and everything seems to work fine. The 250R sprocket even fits on the 400EX hub with a little persuasion. 400EX axle is shorter but the hubs are deep dish, so the length ends up the same.
    To the best of my knowlege, the '86 and up trx 250R axle is interchangeable with the '86 ATC 250R axle. Seems to be the general consensus that the '85 R axle is different, but the difference must be very slight. It's hard to tell with the '85 and '86 axles side by side.
    [FONT="Palatino Linotype"]~My Rides (to name a few) ~
    1986 ATC250R, 1985 ATC350X
    1985 ATC250R Missile (90% done)
    1983 ATC185S
    1999 TRX416EX
    2003 Honda CBR600RR
    1990 Yamaha Zuma
    1985 XR80 w/100 motor
    1967 Honda CB77, '65 CL77
    1962 Puch 250 SGS
    1984 XR350R (owned since I was a kid)
    1972 Suzuki T350 Rebel, '73 T500 Titan
    1964 BSA A65 (needs restored)
    1968 BMW R60/2 mint original bike
    1976 Kawasaki KH500 triple
    Anybody have parts to trade for the above models?
    Live Oak, FL
    15,069
    So the 400ex axle interchanges if you use the carrier also? Thats super good news. That means I can use one of those cheapo G-Force extended axles out of rocky mountain for $200 if I decide to take the plunge and do what I'm thinkin about. Thanks grundlegrabber.
    May 2005
    Fort Worth,Texas (watauga)
    112
    yea,i have the axle out of my 86r in the carrier and swinger on my 85..............i think the carrier`s outer diameter is the only difference there
    trikes owned:
    1982 ATC 185S
    1983 ATC 185S
    (2) 1984 ATC 185S
    1984 ATC 200M
    (2) 1984 ATC 200S
    (3) 1984 ATC 200X
    made one an auto-x,easy swap
    1985 ATC 250R (stolen!...the bastards!...it was mint!)
    own now:
    1985 ATC 250R (running)
    1986 ATC 250R(parts bike)
    1984 ATC 250r w/ 280cc kit in it(pretty rough-needs TLC)
    1984 ATC 200s (running)
    1982 ATC 185s (running)
    (2)1984 ATC 200s(parts)
    1984 ATC 70 (parts)
    1983 ATC 70(off ebay-running)
    1985 ATC 70 (running)
    198? ATC 70 (running)
    1984 ATC 200x (running)(have made it an auto-x until i rebuild the top end of the X motor)
    1985 ATC 200x roller(gonna make another auto-x)
    Eric
    Jackson MI
    1,688
    An 86 axle will fit a 85, but an 85 axle will not fit a 86 without hitting the fat adjustment side of the carrier. The sprocket hub is different on an 85. The 85 sprocket bolts on the right side of the hub & all others including the 400ex bolt on the left side of the sprocket hub. When you put the 86 axle in the 85 carrier there is a big gap where the carrier adjustment is. I just put my TRX +4 axle in my 85-r to run on the oval at sunset. I did grind the adjuster side of a 86 carrier once to make an 85 axle fit. The brake rotor & hubs are the same, but the calipar bracket/ holder are different from 85-86. All the bearings & seals are the same. They just changed to the bigger outer diameter of the carrier for 86 & up.
    Hornetpowerspor's Avatar
    Hornetpowerspor is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Mar 2005
    Michigan
    294
    I think you are right. I recently put a YRX axle in my 85 R with no problems. You put the sprocket to the outside on the newer axles.
    CUYAHOGA FALLS, OHIO
    1,242
    400ex
    I Swapped An 02400ex And An 86 250r Carrier And Axle. Worked Fine. You Will Also Need The Axle Nut Assm.
    Max
    3-85 ATC 70
    86 ATC 250R
    86 WETBIKE
    01 KX250
    2011 KAW SXR800- 35YR EDITION
    05 HERITAGE/SPRINGER/SOFTTAIL
    Live Oak, FL
    15,069
    Awesome info, thanks for the help guys.
