Results 1 to 14 of 14
Thread: Parts interchange master list (you help make it!)
    Jun 2004
    Pyeongtaek, South Korea
    474
    Thumbs up Parts interchange master list (you help make it!)
    I don't know about y'all, but I like to think that there are parts out there from other machines that will interchange with others, even if they aren't from the same manufacturer. About the only things I know are that the 85-86 250R and 83-85 200X front fenders are a direct swap, the swingarms from an 86 ATC250R and a TRX250R swap, and the Tecate-4 and Mojave gas caps are identical.
    Let's get some info out here! Use this thread as a database for info. Know about a Kawasaki part that replaces a hard-to-find one for a Yamaha? List it here.
    Operation Iraqi Freedom V and Operation Enduring Freedom X veteran
    The Constitution and Bill of Rights were written in common English for the common man. There is no interpretation necessary.
    "To err is human, to err continuously is liberal." - Me
    Jun 2004
    474
    I just found this thread that lists parts for the Tri-Z.
    Sep 2005
    N.E.MO
    15
    1979 ATC 110 rear wheel hubs interchange with ATC 200X hubs and also most Yamaha sport quad hubs, (Warrior, Banshee, Raptor).
    Bolt patterns;
    ATC 110 = 3/100mm
    200X = 4/110mm
    Warrior, Banshee, Raptor, YFZ = 4/115mm
    (Exception to above) 89-90 Banshee = 4/156mm
    I have 89-90 Banshee 4/156mm hubs on my ATC 110 with Kawaski Tecate 10 in. wheels!
    Central CA
    459
    The 83-84 250R axle will fit the 86-87 200X
    86 250R
    86 250R
    86 250R
    85 250R
    82 250R
    86 350X
    81 185X
    85 250SX
    87 200X
    Sitting on my can can, doing the pan-o-ram..
    YAMAHA_Jim's Avatar
    YAMAHA_Jim is offline 4 Motos, 3 Wheels, 2 Classes, 1st Place Arm chair racerJust too addicted
    Apr 2003
    Rock Hill,NY
    1,000
    If you go back a few pages on this message brd you will find a few different posts on this topic.
    Alot of the rear end parts on a triz will interchange with thier quads(blaster banshee warrior)not raptor and 450.Also levers,perches,throttles.
    Dec 2007
    521
    great post
    A Rental Car is the only true all-terrain vehicle.
    " I actually think it is good that you have clubs where people can go and enjoy riding these things together. It reminds me of how the prisoners on death row have fun waiting for their turn on the electric chair. Fair enough, the trike isn't an electric chair, but it is about as safe and comfortable as one."
    http://www.nps.gov/bicy/
    topless is offline At The Back Of The Pack Arm chair racerFirst time rider
    Dec 2007
    Kansas
    160
    ATC 70 uses the same sized axle hub & splines as larger ATC's, we used them from a 200s on our 70 to get the 4 lug.
    jeopardy98's Avatar
    jeopardy98 is offline At The Back Of The Pack Arm chair racerAt the back of the pack
    Prince George, VA
    374
    Quote Originally Posted by Rex Karz View Post
    I just ordered one but I'm wondering if the brake parts will interchange. Also which hubs will work with the 250r axle?
    Great post.
    Dec 2007
    Indiana
    235
    EX hubs are direct swaps to the 81R.
    -Phil
    NE Indiana
    1,067
    Well, I've read here that 1983 - 85 KX 250 engines are almost completely interchangeable with 84 - 85 Tecates with some minor exceptions. Also heard that using the KX cylinder is an upgrade that will help "wake up" the Tecate engine.
    Other then that, I'm not sure but I hope the Tecate guys chime in with other stuff that works on an 85 Tecate because I'm restoring one and could use all the help I can get. Finding parts are impossible!
    May 2008
    Juneau
    605
    yt 125 and yt 175 have alot of interchangable parts and blaster rear hubs will fit tri motos rear splines so that you can have 4 lug rims
    Mar 2007
    Texas
    5,045
    barrel and heads from the 185/185s/200/200s/200e are all interchangeable
    seat and wheels from a 81-83 185s-200s interchange only
    ________________
    https://www.mikesatvfix.com
    Maryland
    38
    xr200 cam is interchangeable with 185/185s/200/200s/200e as well as the jug (i'm not a veteran so correct me if i'm wrong bout anything). Just bought an xr200 jug for my 185s
    Mar 2007
    Texas
    5,045
    is the cam on the xr200 more agressive than the 185/200s stuff? if so, i may be lookign for a xr200 cam for my 200e and 185s buildups. :devil:
    ________________
